rollsman4 Posted August 20, 2022 Share #1 Posted August 20, 2022 Advertisement (gone after registration) I see there is a hard wire one but looking for wireless one if it exists Thanks Link to post Share on other sites More sharing options...
Advertisement Posted August 20, 2022 Posted August 20, 2022 Hi rollsman4, Take a look here Is there a wireless remote for the SL. I'm sure you'll find what you were looking for!
Anakronox Posted August 20, 2022 Share #2 Posted August 20, 2022 There is not. If you can connect to the Leica Fotos app, you should be able to trigger the shutter that way. Link to post Share on other sites More sharing options...
helged Posted August 20, 2022 Share #3 Posted August 20, 2022 PocketWizard (and similar devices) works, but you need an adapter plug to get it connected to SLx. Actually, whatever works for Panasonic Lumix S1/S1R/S5/etc also works for Leica SLx with an appropriate adapter plug. Link to post Share on other sites More sharing options...
Anakronox Posted August 21, 2022 Share #4 Posted August 21, 2022 12 hours ago, helged said: PocketWizard (and similar devices) works, but you need an adapter plug to get it connected to SLx. Actually, whatever works for Panasonic Lumix S1/S1R/S5/etc also works for Leica SLx with an appropriate adapter plug. I stand corrected! I was only considering native Leica support. 1 Link to post Share on other sites More sharing options...
Photoworks Posted August 21, 2022 Share #5 Posted August 21, 2022 6 hours ago, Anakronox said: I stand corrected! I was only considering native Leica support. Leica don't make and or these accessories , they just put a label on a compatible one and change you more Link to post Share on other sites More sharing options...
Chuck Albertson Posted August 22, 2022 Share #6 Posted August 22, 2022 On 8/20/2022 at 10:32 AM, helged said: PocketWizard (and similar devices) works, but you need an adapter plug to get it connected to SLx. Actually, whatever works for Panasonic Lumix S1/S1R/S5/etc also works for Leica SLx with an appropriate adapter plug. If you can find an appropriate cable for the PocketWizard (USB 3.0 micro-b plug to 3.5mm plug), do let us know. PocketWizard doesn't make one, and I haven't even been able to spot one on Amazon. Link to post Share on other sites More sharing options...
rollsman4 Posted August 22, 2022 Author Share #7 Posted August 22, 2022 Advertisement (gone after registration) Ok Thank you. I just might use the Self timer instead Link to post Share on other sites More sharing options...
Paul2660 Posted August 23, 2022 Share #8 Posted August 23, 2022 Not sure if the MIOPS adapter will work on the SL, it works fine on the SL2. If it does, it's a great solution to a wireless trigger for the SL. https://www.miops.com/products/splash-water-drop-kit?utm_source=miops_newsletter&utm_medium=email&utm_campaign=lumecsplash&ml_subscriber=1990327590224663633&ml_subscriber_hash=f9a6&utm_term=2022-08-23 Paul Link to post Share on other sites More sharing options...
