Sigma is introducing two new wide-angle fixed focal lengths for full-frame cameras (L-mount and Sony E-mount), the SIGMA 20mm F1.4 DG DN and SIGMA 24mm F1.4 DG DN.
Both lenses will be launched by end of August and will cost $ 899 /  (SIGMA 20mm F1.4 DG DN) and $ 799 (SIGMA 24mm F1.4 DG DN). Both lenses are available for pre-order at B&H:
For both lenses, Sigma emphasizes that are suitable for astrophotography.
Product Images SIGMA 20mm F1.4 DG DN
Product Images SIGMA 24mm F1.4 DG DN
SIGMA 20mm F1.4 DG DN / SIGMA 24mm F1.4 DG DN at a glance
  • Lens construction
    • 17 elements in 15 groups, with 2 SLD, 3 aspherical lens elements (Sigma 20mm)
    • 17 elements in 14 groups, with 2 FLD, 1 SLD, 4 aspherical lens elements (Sigma 24mm)
  • Inner focus system
  • Compatible with high-speed autofocus
  • Stepping Motor
  • Front filter thread 72mm (Sigma 24mm) / 72mm (Sigma 20mm)
  • Compatible with Lens Aberration Correction
  • Function available on supported cameras only. Available corrections and auto correction functionality may vary depending on the camera model.
  • On cameras where lens aberration correction is controlled with “ON” or “OFF” in the camera menu, please set all aberration correction functions to “ON” (AUTO).
  • Support for DMF and AF+MF
  • Compatible with AF assist (Sony E-mount only)
  • Nano porous coating
  • Super Multi-Layer Coating
  • Water- and oil-repellent coating
  • Aperture ring
  • Aperture ring click switch
  • Aperture ring lock switch
  • AFL button
  • Programmable function only on compatible cameras. Available functions may vary depending on the camera used.
  • Manual Focus Lock (MFL) switch
  • Rear filter holder
  • Focus mode switch
  • Support for switching between linear and non-linear focus ring settings (L-Mount only)
  • Petal-type lens hood with lock (LH782-01)
  • Dust- and splash-resistant structure
  • Compatible with SIGMA USB DOCK UD-11 (sold separately, L-Mount only)
  • Designed to minimize flare and ghosting
  • Every single lens is evaluated with SIGMA’s proprietary MTF measuring system
  • 11-blade rounded diaphragm
  • High-precision, durable brass bayonet mount
  • “Made in Japan” craftsmanship
If you are interested in Astro photography: I like this channel a lot and he compared the two new lenses with some competitors. As far as I can tell the 20mm's main flaw is it's vignette wide open. But I think that's manageable with proper lens profiles in Lightroom (or other tools) and by stopping down a bit. I think that will be the ultrawide I get at some point. Too bad Panasonic didn't release the 18mm yet 😕
Edited by scrollt
  • 1 month later...
  • 1 month later...
