atournas Posted July 31, 2022 Share #1 Posted July 31, 2022 (edited) Advertisement (gone after registration) Do M9 owners here use non-Leica batteries? And if so, could one advise on 1600 mAh vs. 1800 mAh? Is only for getting more shots per charge? Thanks. Edited July 31, 2022 by atournas Link to post Share on other sites More sharing options...
Advertisement Posted July 31, 2022 Posted July 31, 2022 Hi atournas, Take a look here Non-Leica battery for M9 . I'm sure you'll find what you were looking for!
TomB_tx Posted July 31, 2022 Share #2 Posted July 31, 2022 Sorry - I still use the 2 original Leica batteries I got in about 2010 when the camera was new. With life like that I see no reason to try anything else. 1 Link to post Share on other sites More sharing options...
pedaes Posted July 31, 2022 Share #3 Posted July 31, 2022 2 hours ago, atournas said: o M9 owners here use non-Leica batteries? Only if they want problems. Try a search. Link to post Share on other sites More sharing options...
atournas Posted August 1, 2022 Author Share #4 Posted August 1, 2022 Thanks for your response. Yes, not a good alternative, just 3 or more times cheaper. If they survive! Link to post Share on other sites More sharing options...
Ko.Fe. Posted August 19, 2022 Share #5 Posted August 19, 2022 I use Leica official battery which is made in China and two made in China ten times less expensive batteries. No problem since 2016. But one quirk. No, two. Once MiC non Leica labeled is fully charged and in camera it will give low battery warning after some exposures taken. All I have to do is to press shutter release (take exposure) and it shows true charge level after it. Second quirk, if this battery is not discharged by use in camera, Leica charger will not charge it. Based on dozens threads like this, I assume many, if not most, who declared their MiC non Leica labeled as been dead soon, just been not smart enough to figure what I did. Sorry. 1 Link to post Share on other sites More sharing options...
RobsonCabanas Posted October 12, 2022 Share #6 Posted October 12, 2022 On 8/19/2022 at 2:14 PM, Ko.Fe. said: I use Leica official battery which is made in China and two made in China ten times less expensive batteries. No problem since 2016. But one quirk. No, two. Once MiC non Leica labeled is fully charged and in camera it will give low battery warning after some exposures taken. All I have to do is to press shutter release (take exposure) and it shows true charge level after it. Second quirk, if this battery is not discharged by use in camera, Leica charger will not charge it. Based on dozens threads like this, I assume many, if not most, who declared their MiC non Leica labeled as been dead soon, just been not smart enough to figure what I did. Sorry. What is the of brand that you use? Link to post Share on other sites More sharing options...
Ko.Fe. Posted October 22, 2022 Share #7 Posted October 22, 2022 Advertisement (gone after registration) On 10/12/2022 at 7:38 PM, RobsonCabanas said: What is the of brand that you use? https://www.l-camera-forum.com/topic/286547-leica-m8-replacement-battery-type-14464/?do=findComment&comment=3555870 Link to post Share on other sites More sharing options...
IR-zero Posted October 23, 2022 Share #8 Posted October 23, 2022 On 8/19/2022 at 6:14 PM, Ko.Fe. said: I use Leica official battery which is made in China and two made in China ten times less expensive batteries. No problem since 2016. But one quirk. No, two. Once MiC non Leica labeled is fully charged and in camera it will give low battery warning after some exposures taken. All I have to do is to press shutter release (take exposure) and it shows true charge level after it. Second quirk, if this battery is not discharged by use in camera, Leica charger will not charge it. Based on dozens threads like this, I assume many, if not most, who declared their MiC non Leica labeled as been dead soon, just been not smart enough to figure what I did. Sorry. I've had a similar experience with a non-leica replacement battery. I take "with a pinch of salt" what the battery gauge on the camera shows and keep shooting till it stops after 150 or more pics (I can't remember exactly how many pics a full battery can take). It doesn't interfere with my enjoyment or use of my second hand M9 Link to post Share on other sites More sharing options...
