Just started using the Q2M. Do I need to be concerned about unsharp captures using the 3 or 5 Exposure Bracketing mode.
I use a tripod and 2 second delay. Also been using the Extended Shutter option. Does anyone know if the Electronic Shutter range is  120 s to 1/4000? If I want to shoot below 1/2000 is the only option the mechanical shutter, correct?
Would electronic shutter be more still than mechanical shutter?
Would it be better to bracket using a single shot method? I really like the rapid Exposure Bracketing but I’m not sure if it causes camera shake?
Thank you!
If you use a program like Photomerge,Luminar Neo  or similar any camera movement -within reason-between the shots will be compensated by the software. You can bracket handheld.
and sometimes actually gives a better result
BTW, the same goes for focus stacking which I use far more often than exposure bracketing. For Macro it is indispensable and landscape benefits quite often as well, whereas the wide dynamic range of present-day cameras gets us close to HDR with a single exposure.
I’ve done bracketing many times on a Q2 with tripod and a 2 sec. delay. I don’t remember any unsharp photos unless I didn’t focus properly. Is your tripod solid? 99% of the time I use the mechanical shutter. It works fantastic. I’ve had no reason not to use it. I’m usually at low ISO, whatever aperture I want for DOF or just F/8 for best sharpness. Then I let the shutter go where it wants. I’m doing landscapes for this setup. Works every time. In post I either choose the exposure I like best or I combine using HDR in LR. Good luck.
This is an example - Chain Bridge in Budapest, Hungary at dusk
Thank you!
Why not take your own comparison shots between mechanical and electronic and see which you think is sharpest?
Q/Q2/Q2M mechanical shutter is a leaf shutter, and it produces no shutter shock. Feel free to use it at any available shutter speed for high-IQ capture. Electronic shoots any speed and can shoot at higher speeds than the mechanical leaf shutter.
