ivohula Posted July 5, 2022 Share #1  Posted July 5, 2022 Advertisement (gone after registration) I have a late model (sr 272xxxx) M6 TTL and the frame counter is acting up.  It counts correctly although resets anywhere from 0 to +5 when the bottom plate is removed (normally it should be -2). This is caused by a slipping frame counter disk ?? and is a common issue with the Leica M6, M7, MP and M-A models, says DAG. DAG (Don Goldberg) has quoted me $165 for this repair. Has anyone had this issue? Is it common? Should I worry about it? Can I just use the camera and make a mental adjustment about my exposure count. After all, when the film stops advancing, then you just know to remind. Link to post Share on other sites More sharing options...
Advertisement Posted July 5, 2022 Posted July 5, 2022 Hi ivohula, Take a look here Faulty M6 TTL Frame Counter. I'm sure you'll find what you were looking for!
logan2z Posted July 5, 2022 Share #2  Posted July 5, 2022 I've never experienced this issue with my M-A. If I did, though, I don't think I'd send my camera in specifically for this repair since, as you say, it's obvious when you hit the end of the roll. I'd wait and have it fixed whenever the camera requires a CLA. Link to post Share on other sites More sharing options...
Helge Posted July 5, 2022 Share #3 Â Posted July 5, 2022 (edited) I would get it repaired considering the pretty low price DAG is quoting. And maybe you combine it with a CLA (depending on how long ago the last one was done) to save time. Edited July 5, 2022 by Helge Link to post Share on other sites More sharing options...
Matlock Posted July 5, 2022 Share #4 Â Posted July 5, 2022 I have the same problem with my M5. As Don says it is a common fault with M series cameras. I just live with it. Â Link to post Share on other sites More sharing options...
cornbarn Posted July 5, 2022 Share #5  Posted July 5, 2022 My M6 Classic had the same problem and I lived with it for some time.  Eventually I decided to get it fixed as part of a CLA. That was in 2014 and it has been faultless since. Tony  Link to post Share on other sites More sharing options...
Anbaric Posted July 5, 2022 Share #6 Â Posted July 5, 2022 Perhaps there's something to be said for the manually reset counters on the M2 and the LTM cameras! If this were me, it would be irritating enough to get it fixed, and the price seems reasonable by Leica standards. You might pay that to buy and process half a dozen rolls of colour film these days. Link to post Share on other sites More sharing options...
Huss Posted July 5, 2022 Share #7  Posted July 5, 2022 Advertisement (gone after registration) Common issue w lots of M cameras.  DAG’s quote is a lot less than other places so I’d fix it now and be done with it. Been there, done that! Link to post Share on other sites More sharing options...
ivohula Posted July 5, 2022 Author Share #8 Â Posted July 5, 2022 Do you think that this fault indicates heavy use in the past? If it is a weak mechanical point in the design, then they tend to emerge in heavy use. Link to post Share on other sites More sharing options...
Matlock Posted July 5, 2022 Share #9 Â Posted July 5, 2022 21 minutes ago, ivohula said: Do you think that this fault indicates heavy use in the past? If it is a weak mechanical point in the design, then they tend to emerge in heavy use. I think it is an inherent fault with the M type counter so it probably has no connection with usage. 1 Link to post Share on other sites More sharing options...
