Wendy165 Posted June 25, 2022 Share #1 Posted June 25, 2022 Advertisement (gone after registration) When using theQ2 Monochrom, the plus sign used to mark the center of the focus area on my camera’s screen moves very easily. I shoot from the hip and as the camera brushes against me the plus moves away from center, usually to one of the bottom corners. If I don’t check regularly, I can end up with an entire out of focus photo shoot. Is there a way to lock the plus sign in the center of the screen? Link to post Share on other sites More sharing options...
Advertisement Posted June 25, 2022 Posted June 25, 2022 Hi Wendy165, Take a look here “Plus Sign” focus mark moves too easily. I'm sure you'll find what you were looking for!
clasami Posted June 25, 2022 Share #2 Posted June 25, 2022 Touch Screen is disabled on my camera. No need for it. That should solve you problem also. 1 Link to post Share on other sites More sharing options...
jaapv Posted June 25, 2022 Share #3 Posted June 25, 2022 The wandering focus point is extremely annoying, not only on the Q, and there are numerous complaints to be found on the forum. A double tap on the screen will centre the focus point. 2 1 Link to post Share on other sites More sharing options...
Mikep996 Posted June 25, 2022 Share #4 Posted June 25, 2022 I operate my Q2 in the EVF extended mode (I think that's the right term) whereby the rear screen is never active unless I hit menu or play. I prefer using the viewfinder when taking pics but I can see that for someone who prefers using the rear screen, the moving focus point would be EXTREMELY annoying. Maybe Leica will make a firmware update to fix it. ?? 1 1 Link to post Share on other sites More sharing options...
Le Chef Posted June 25, 2022 Share #5 Posted June 25, 2022 Welcome to the world of Leica Rapid Customer Response! This is a 5 year discussion on this and other fora, and Leica either don't know how to change this, don't want to change this or are oblivious to the numerous requests from owners. The simple thing would be to make the moving focus point as "Off" as the default, and if you want it to move you change the default. 3 1 Link to post Share on other sites More sharing options...
