ejg1890 Posted April 19, 2022 Share #1 Posted April 19, 2022 Advertisement (gone after registration) Curious if the above set up is sufficient to digitize negatives for the computer and import into Lightroom? Previous articles and videos indicates a micro lens would be required. However, I read a recent article where a Nikon Z6 w/ 24-120/4 lens was utilized. While I don’t have that lens I do have the 24-70/4. I had been looking at selling the setup along with the 14-30/4 as the are little used these days and use the proceeds to fund a scanner. However, if the Nikon Z6 w/ 24-70/4 works for snapping a raw file of the negative I can then transform that to a photo with software and not bother with the scanner. If the camera/lens set up would work what remaining hardware is required and does anyone sell it as a complete set up or kit? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted April 19, 2022 Posted April 19, 2022 Hi ejg1890, Take a look here Digitize Negatives - Nikon Z6 w/ 24-70/4 lens. I'm sure you'll find what you were looking for!
250swb Posted April 19, 2022 Share #2 Posted April 19, 2022 (edited) I think you need a lens that can give you a flat plane image without distortion. So either an enlarging lens with an adapter or a Nikon micro lens, maybe the 60mm AF-D, with the FTZ adapter. You are looking at recording 'flat to flat', as a film scanner does it. Edit, FWIW I use my Z7 with the 60mm micro to copy/scan my negatives. Edited April 19, 2022 by 250swb Link to post Share on other sites More sharing options...
ejg1890 Posted April 19, 2022 Author Share #3 Posted April 19, 2022 1 hour ago, 250swb said: I think you need a lens that can give you a flat plane image without distortion. So either an enlarging lens with an adapter or a Nikon micro lens, maybe the 60mm AF-D, with the FTZ adapter. You are looking at recording 'flat to flat', as a film scanner does it. Wouldn’t Lightroom’s camera/lens correction fix that issue? Link to post Share on other sites More sharing options...
oldwino Posted April 20, 2022 Share #4 Posted April 20, 2022 When I owned the Z6, I bought a used AF-S 60 micro lens for scanning purposes. It worked great. No need to re-invent the wheel. I think using a 24-70 would be difficult. Link to post Share on other sites More sharing options...
250swb Posted April 20, 2022 Share #5 Posted April 20, 2022 8 hours ago, ejg1890 said: Wouldn’t Lightroom’s camera/lens correction fix that issue? The 24 - 70 is a great lens but it's not nearly as sharp close up as a micro lens. I don't know if software would correct any distortions, but on my Z7 it won't focus anywhere near close enough to copy a negative properly, there would be a lot of wasted pixels around it. Sure it's possible to get something and that is all some people want, a simple representation of the negative, but it will be a bit crude. You could possibly cut the costs by getting a simple Z to F mount adapter and a 55mm Micro Nikkor. Link to post Share on other sites More sharing options...
ejg1890 Posted April 22, 2022 Author Share #6 Posted April 22, 2022 Thanks for all the responses. I have another follow up. The 50mm 2.8Z and 60mm 2.8G are both 1:1 for macro while the 55mm 2.8 AI the object appears at half its size so not 1:1. Is a 1:1 ration required for the macro/micro lens? Thanks Link to post Share on other sites More sharing options...
250swb Posted April 22, 2022 Share #7 Posted April 22, 2022 Advertisement (gone after registration) 3 hours ago, ejg1890 said: Thanks for all the responses. I have another follow up. The 50mm 2.8Z and 60mm 2.8G are both 1:1 for macro while the 55mm 2.8 AI the object appears at half its size so not 1:1. Is a 1:1 ration required for the macro/micro lens? Thanks Ideally 1:1. Link to post Share on other sites More sharing options...
ejg1890 Posted April 22, 2022 Author Share #8 Posted April 22, 2022 Thanks all. I have decided to go with the Nikon Z MC 50mm 2.8 over the 60mm 2.8G as the 50mm is much smaller, a native fit to z6, 1:1 and focus closer than the 60mm. Link to post Share on other sites More sharing options...
250swb Posted April 22, 2022 Share #9 Posted April 22, 2022 5 hours ago, ejg1890 said: Thanks all. I have decided to go with the Nikon Z MC 50mm 2.8 over the 60mm 2.8G as the 50mm is much smaller, a native fit to z6, 1:1 and focus closer than the 60mm. You'll probably find that is fine and get you in the zone, although a lens that can do micro isn't necessarily a lens that is made specifically for micro. So if it doesn't have a micro (Nikon) or macro (everybody else) name attached to it in the name of the lens, just check again. Link to post Share on other sites More sharing options...
Sandokan Posted May 1, 2022 Share #10 Posted May 1, 2022 (edited) Just get the Nikon ES2 as it saves a lot of time fiddling around aligning slides or negatives. You need the Nikkor Micro lens too (I bought the 60mm). I use it with my SL with the Nikon G to L adaptor (e.g. Urth) but will work on any camera with a lens adaptor Edited May 1, 2022 by Sandokan Link to post Share on other sites More sharing options...
roydonian Posted May 1, 2022 Share #11 Posted May 1, 2022 If you have an existing lens, try it and see how effective it is in this role. Faced with the need to digitise a collection of BW negatives dating from the late 1940s and 1950s, I used a Leitz BEOON copying stand, and experimented with most of my vintage 50mm lenses to see which one worked best. To my surprise, the lens that outperformed the others in this role was a late-1930s 5cm Elmar. Link to post Share on other sites More sharing options...
