Jk1002 Posted April 11, 2022 Share #1  Posted April 11, 2022 (edited) Advertisement (gone after registration) I have the battery grip almost permanently glued to my Sl 601.  Question, for tripod usage, is there a base plate that works reasonable well for this combo? Ideally I want QD but am worried that the RRS generic plate does not fit. Hard to say from the dimensions and pictures. I know there is also a Leofoto which might be a bit more flexible.  Also I know Leica is selling a co branded version of the Peak Design tripod. Is that a decent combo? Specificlly, does the head moved after locking it down? No reviews I could find talk about that but that is often a problem it seems  Best JK Edited April 11, 2022 by Jk1002 Link to post Share on other sites More sharing options...
Advertisement Posted April 11, 2022 Posted April 11, 2022 Hi Jk1002, Take a look here Arca plate with the Sl 601 and battery grip. I'm sure you'll find what you were looking for!
Alexander SH Posted April 11, 2022 Share #2  Posted April 11, 2022 RRS pure quality and works great. Have mine attached most of the time. https://www.bhphotovideo.com/c/product/1301075-REG/really_right_stuff_bsl_l_plate_set_l_plate_set_for_leica.html   Link to post Share on other sites More sharing options...
Sandokan Posted April 11, 2022 Share #3  Posted April 11, 2022 If I can find my battery grip, I can try later this week. What do you mean QD? I believe Leica used to rebrand/promote tripods from FLM. I have the RRS L plate for the 601 permanently attached as I never ran out of juice but do use the camera on a tripod frequently. Most Arca-Swiss plates will fit onto the battery grip but not as stable as the L plate. I believe there is a generic L plate for use with vertical battery grips. I have not been impressed by Peak Design's designs, especially their bags. I have not seen great reviews from landscape photographers on the Peak Design tripods. For a tripod, I stick to Gitzo and ProMediaGear and would get a RRS if a Gitzo needed replacement. All are expensive but I went through the same cost in multiple cheap tripods and heads until I bit the bullet. For heads I have the following Gitzo gimbal, Arca-Swiss P0 but have discovered pan & tilt heads with one knob to release both dimensions which works really well: Induro PHD3 and Acratech. Of course Barlebach and Riess make fantastic tripods and Reiss' heads are exceptional but the weight is too much for me to carry these. 1 Link to post Share on other sites More sharing options...
Jk1002 Posted April 11, 2022 Author Share #4  Posted April 11, 2022 I think the RRS base  Plate might work with the grip, since the holes are in the same position on the grip. I do prefer to use the SL with grip, have a hand strap attached, its easier to hold this way for me, my hand is more relaxed. Not so much a power issue. Its just a pain to take off. Best JK Link to post Share on other sites More sharing options...
