On 3/22/2022 at 7:29 PM, Marc B-C said:
I sadly had to give that up due to deteriorating  eyesight and focusing issues
The RF depends on visual acuity and whilst the rangefinders may be slightly better on recent models, they still rely on visual acuity and user determination of coincidence and this has nothing to do with the focal length of the lenses you ask about. If you found the M6 and 35/2 unacceptable to use I wouldn't think that a replacement will be significantly easier. Wider lenses may be more fogiving on slight misfocus is about all I can say. I am aware that at some point an M will no longer be my ideal camera because it relies on good visual acuity. I don't like this potentiality but feel it better to accept it than do anything else.
My first 28mm lens, used on my M10 and M Type 246 cameras, was an Elmarit-R 28mm, with a Novoflex LEM/LER adapter, which I have almost always focused using the distance and DOF scales on the lens, rather than using the LCD in live view. R lenses are not rangefinder coupled, when used with the adapter, but this was/is not a problem, with a 28mm lens. The chief disadvantage is that the R lens, with the adapter, is a quite large combination.
When I did my a 28mm M lens, a Version 3 Elmarit-M, I have generally continued to zone/scale focus, and this does include while photographing my toddler grandsons, as they are playing, and running about. I can focus with the rangefinder, but zone/scale focusing is SO much quicker, when using wide-angle lenses, with their ample DOF. Looking downward, at the scales, on the top of the lens, works well when holding the camera at their level.
Yes, I did buy the M10 first. While my M10 was out of service, after a mishap, I bought a pre-owned 246 Monochrom. There is nothing, at all, wrong with choosing 240-series cameras, except the ISO limitation of the color cameras. (The Type 246 Monochrom is as capable, at high ISO, as the M10.) The viewfinder experience, for those of us wearing eyeglasses, is better with an M10, but the difference is, in my humble opinion, incremental.
Thanks all for the input. I am still considering the M240 / 28mmm Elmarit, however, some concerns re ISO (not above 1600) are now slowing me down. The self allocated budget certainly allows this combo to work, however, as the wish is more romantic than cerebral, so will see how I feel in a week.
  • 3 weeks later...
