75mm Summicron filter ring problem
dcoombs
Recently I unscrewed a filter from my 75mm cron and a second (retaining?) ring came off the lens with it! Must have screwed the filter on too tight, obviously. I was able to screw the ring back onto the lens and nothing else seemed to be loose, but it now can unscrew easily. On the outside of the ring there were several white paint or glue spots.
Has this happened to any of you and is it something to be concerned about or just a nuisance?
Doug
x
