Rosebud55 Posted March 5, 2022 Share #21  Posted March 5, 2022 Advertisement (gone after registration) I was getting so many dust spots on my CL I took it to Leica for a free clean. Then next day more dust spots! So I now use a blower every time I change the lens and it’s made a huge difference. If I do get one I just sort it out in LR now and don’t worry too much. it was a lot harder to remove dust spots from negatives before printing!  I wouldn’t worry too much just use the spot removal tool in LR.  rosie Link to post Share on other sites More sharing options...
Advertisement Posted March 5, 2022 Posted March 5, 2022 Hi Rosebud55, Take a look here Dust on sensor?. I'm sure you'll find what you were looking for!
Astropap Posted March 5, 2022 Author Share #22 Â Posted March 5, 2022 Good idea! Link to post Share on other sites More sharing options...
geoffreyg Posted March 5, 2022 Share #23  Posted March 5, 2022 Quit common issue with digital sensors. The trick is getting a camera where it is easy to clean. They are inevitable. On larger sensors use a blower first, then cleaning fluid on a wipe, folded on a plastic sheet for holding it in place. For smaller sensors, blower first usually does the trick. If not, then wipe with a bit of fluid on it, using pre-sized wipes. Link to post Share on other sites More sharing options...
Astropap Posted March 5, 2022 Author Share #24 Â Posted March 5, 2022 Any thoughts on that one spot just showing when I use one of the Silver Efex presets? Link to post Share on other sites More sharing options...
PDP Posted March 6, 2022 Share #25  Posted March 6, 2022 I have discussed the issue with Leica and learned on informal basis that the CL has a severe issue, the sensor seems to be quite static and „collecting“ dust when changing lenses. During first days of a workshop this made me mad and I have used a complete pack of swabs. A solution is to switch of the camera and wait for a while before changing the lens (or having just one lens per day). The SL2 does not have this issue… 1 Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted March 6, 2022 Share #26  Posted March 6, 2022 The sensor does require more cleaning than my M8 or previous Nikons. It hasn't been a debilitating issue. I never leave the camera with out a lens and try to change lenses as quickly as possible. What I do notice with the CL is the two TL lenses I have, 23 and 11-23 front elements tend to be very dusty, was wondering about static and the camera too, non TL lenses don't have this problem, using M lenses and L mount 7 Artisans all manual. The last sensor issue was with a 400 Telyt I hadn'tused ina while and probably had some residual dust in it.  Link to post Share on other sites More sharing options...
