Hi Everyone
I was playing around with the M11 last night and noticed that the small red led dot indicating exposure lock ( when the shutter is half pressed ) does not come on anymore.  I looked in the M11 manual and the manual discusses it as well.  I know the little green icon next to the shutter speed display comes on when the exposure is locked comes on but no red dot in the off.  I should note that the exposure does not change if I half press the shutter and point the camera at an area which would normally change the exposure, as designed.
I was wondering if other folks are seeing the same behavior as well or if it is a problem with my copy?
Perhaps they started with the M10 manual and forgot to update the manual with the change?
Thanks
Eric
1 hour ago, eab said:
Hi Everyone
Thanks
Eric
This seems like a bug to me.
Does it behave this way in all metering modes? Multi-field metering tends to make exposure lock irrelevant as the camera is metering off the whole scene, which could be an explanation, although other cameras usually let you lock exposure even if it doesn’t change when you recompose.
Ian
Ian
Yes, I checked in all modes.
Not meaning to hijack your post, but I thought you may be able to check and confirm another strange thing I noticed yesterday. On your M11, with live view switched off, press play to bring up the photo you last shot on your LCD.  With the image still on your screen, look through your OVF and check the LEDs - they are frozen on my camera when an image is being displayed on the LCD. Same thing if I am inside the main menu structure (but not if I'm on the quick menu screen).
Once I half press the shutter, or change the shutter speed dial, the metering becomes active again - but until then the LEDs are paused, and no amount of changing aperture ring will unfreeze them.
On my M10R this is not the same - the metering is active even with an image or menu showing on the rear LCD, and changing the aperture ring triggers a response from the meter.
Yes, metering is blocked when the image is reviewed; half-press cancels image review and wakes up metering.
The software in M11 seems to be completely new. It is not clear to me if this is works-as-intended or a bug.
Edited by SrMi
  • 4 months later...
