hmathias Posted January 16, 2022 Share #1 Posted January 16, 2022 Advertisement (gone after registration) Hello All, I am very impressed with the specs of the new M11. I trust Leica to improve their performance with ever new camera. I have seen massive improvements on every M series camera from my old M9 to my current M10 and SL. I know quite a bit about camera sensor technology from my use and study of digital cinema camera sensors. But, sensor backside illumination (BSI) is a new technology to me. I would like to know more about it. Thanks! Some of my work is on: HarryMathiasImages.com Link to post Share on other sites More sharing options...
Advertisement Posted January 16, 2022 Posted January 16, 2022 Hi hmathias, Take a look here M 11 Does anyone know what the significance (advantage) of sensor backside illumination (BSI) is? . I'm sure you'll find what you were looking for!
onasj Posted January 16, 2022 Share #2 Posted January 16, 2022 (edited) A simplified explanation is that each sensor element has to capture incoming photons with a photodiode to transduce the photons into an electrical signal that allows us to record an image. Traditional CMOS sensors are 'front-side illuminated', meaning that the light passes from the micro lens above each sensor element through a circuitry layer and then the photodiode layer. The presence of the circuitry layer between the microlens layer and the photodiode layer causes significant light loss, especially for light that comes in from more of a sideways angle—such as the light in the corners of an image, or light from a wide-angle lens. Back-side illuminated (BSI) sensors move the circuitry layer to behind (after) the photodiode layer, so the incoming light can go straight from the microlens layer to the photodiode layer, without being bottlenecked by the circuitry layer. The net result is that a front-side illuminated CMOS sensor shows lower light sensitivity (higher noise per incoming photon) and more vignetting, especially for wide-angle lenses, than BSI sensors. There are variations on both FSI and BSI designs that improve light sensitivity. But all other things being equal, BSI sensors can offer superior image quality compared to FSI sensors. The figures below are from Stemmer Imaging. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited January 16, 2022 by onasj 2 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/328601-m-11-does-anyone-know-what-the-significance-advantage-of-sensor-backside-illumination-bsi-is/?do=findComment&comment=4358018'>More sharing options...
SrMi Posted January 16, 2022 Share #3 Posted January 16, 2022 The main advantages of BSI sensors in FF format are faster readout and better handling of steep incident angles. It is possible that Leica could implement a better live view experience thanks to a faster readout. Also, some lenses benefit from less vignetting and sharper corners. 1 2 Link to post Share on other sites More sharing options...
hmathias Posted January 16, 2022 Author Share #4 Posted January 16, 2022 Excellent explanation, Onasj. Thanks hmathias Link to post Share on other sites More sharing options...
