So on the M240 there is an advanced metering option where when focusing/metering using the rangefinder Matrix metering is used instead of center-weighted metering. Basically the moment before the exposure happens the shutter opens so the camera can take a reading off the sensor using Matrix metering, then the shutter closes, and then the shutter opens to make the exposure. I was watching a video on the M10 that said it had the same feature, but I'm just seeing three options in my metering modes. My M10 has Matrix metering, Center-weighted, and spot. From what I can tell the Matrix and Spot metering only work in Live-view. It seems like on my M10 that if I have the metering mode set to Matrix metering, but am focusing using the rangefinder, the meter defaults to counterweighted. It doesn't seem like the M10 has this "Advanced" metering option; which I view as a good thing as I don't want my shutter opening just to take a meter reading.
Both the M240 and M10 (as well as prior M iterations) use only center weighted metering when using the RF.  Advanced metering options require reading off the sensor, i.e., live view mode.  (The M11 apparently will be in constant LV mode, permitting multiple metering options at all times.)
Jeff
Jeff
The M240 has an Advanced Metering option in the menu that when the camera is set to this, and you are focusing using the Rangefinder instead of Live-view, it opens the shutter prior to the exposure (to take a Multi-field meter reading directly off the sensor), then closes the shutter, and then opens the shutter to take the exposure; this is all done while using the Rangefinder to focus without the camera being in Live-view at all. By using this mode on the M240 you get to take Multi-field meter readings while shooting using the rangefinder instead of Live-view to compose and focus your image.
But advanced metering is still happening in live view.
https://www.overgaard.dk/Leica-M-Type-240-aka-Leica-M10-digital-rangefinder-camera-page-31-lightmetering-white-balance-simplicity.html
Jeff
1 minute ago, Jeff S said:
Well, yes, I guess technically. You don't see it. The  reading that is being taken off the sensor prior to exposure is merely a meter reading, and what the sensor is seeing is not displayed on the screen. The only way you really know something is different at all is the Multi-field metering icon is displaced in the image information after-the-fact, and more pertinent the time it takes to make the exposure is approximately doubled, and it sounds different than a Center-weighted exposure using the rangefinder.
12 minutes ago, Jeff S said:
RF classic metering is center weighted only. That hasn’t changed.  Yet.
Jeff
True. What I'm really trying to confirm is if I have my M10 set to Multi-field metering in the menu, but I'm shooting with the rangefinder, is the image metered off the shutter curtain using centerweighted metering, or instead does it act like the M240 in advanced metering mode where it uses Multi-field metering off the sensor itself?
As discussed, any metering other than classic center weighted requires reading off the sensor, i.e., live view, whether M240 or M10.  Prior CCD sensors without live view capability therefore couldn’t offer these alternative modes.  The M11 will offer more.
Jeff
Jeff
Hey, Jeff,
I'm sorry if I'm being confusing, or if I'm somehow confused. Not really what I am asking. I understand that all meter readings other than classic center-weighted meter readings are taken off the sensor. In advanced metering on the M240 the reading is taken off the sensor, but the camera is not in Live-view; instead the shutter opens up prior to the exposure to take a reading off the sensor for multi-field metering, then the shutter closes, and then the shutter opens back up to take the exposure; in this metering mode on the M240 the camera is never in Live-view when it is taking a reading off the sensor directly. I'm merely trying to confirm, or dismiss, if the M10 acts the same when set to Multi-field metering in the menu and you are shooting using the rangefinder instead of Live-view.
Yes it is, however it gets there. But I no longer have the M240, so I can’t recall the exact implementation. Plus I only use center weighted metering on all my M bodies (since the 80’s, now including the M10), so someone else will have to chime in.
Jeff
24 minutes ago, AllNoAll said:
Hey, Jeff,
The M10 doesn't have non-live view meter modes. Choice of spot, center or matrix in live view. I suppose if you wanted spot or matrix you could just use live view and cover the display while focusing with the rangefinder.
Edited by charlesphoto99
Now I’m confused for sure. So on the M10 all meter readings are read off the sensor, regardless if you are using live-view or not? Why is there a sensor built into the base of the camera then, and why would the shutter curtains be shades of grey?
No, M10 RF is classic metering, not off sensor.  M11 will apparently offer full time LV metering.
Jeff
Edited by Jeff S
Jeff
That’s what I thought. Am I not making sense at all?
What I’m asking is…when the M10 is set to Multi-field metering in the camera menu, and you are shooting using the rangefinder (no live-view), does the camera meter off the center-weighted meter in the base of the camera, using light bounced off the shutter curtains, or does it open the shutter to meter off the sensor because you have the camera set to multi-field metering that can only be done using the sensor?
M-Type 240 has a menu setting that allows you to use advanced metering without pressing the live view button. When it is set to advanced metering a half press of the shutter button opens the shutter to meter off the sensor. As far as I know that setting went away on the M-10.
Okay, to state it plainly: if you shoot the M10 in rangefinder mode without Live view on, it ONLY meters center-weighted off the shutter curtain.  ANY OTHER metering modes are only available in Live View and are read off the sensor with the curtain open.  In that scenario, the shutter has to close again before the shot is taken.  Hope that answers the OP’s question.
Thanks! Perfect!
