Lawly Posted January 10, 2022 Share #1 Posted January 10, 2022 Advertisement (gone after registration) Took my recently acquired Q2 for a walk around Dublin Ireland yesterday and was surprised at the degree of distortion when I captured images holding the camera portrait hold and pointing the lens up. See the attached image with buildings on the right leaning to the left. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/328279-q2-distortion-in-portrait/?do=findComment&comment=4350450'>More sharing options...
Advertisement Posted January 10, 2022 Posted January 10, 2022 Hi Lawly, Take a look here Q2 distortion in portrait. I'm sure you'll find what you were looking for!
jaapv Posted January 10, 2022 Share #2 Posted January 10, 2022 And on the left leaning to the right. With a wideangle lens hold your camera straight and parallel to the verticals. Otherwise you will always see this effect - with any camera and any wideangle. Easy to correct in post (Cleaned exposure and colour up a bit as well ) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/328279-q2-distortion-in-portrait/?do=findComment&comment=4350486'>More sharing options...
jankap Posted January 10, 2022 Share #3 Posted January 10, 2022 In Photoshop take "Filter" and then "Adaptive Wide Angle" as the first step. To avoid the effect, you should keep the camera vertical. And loose a lot of room at the bottom.😒 Link to post Share on other sites More sharing options...
jaapv Posted January 10, 2022 Share #4 Posted January 10, 2022 I normally use "Lens Correction" and "Custom" in Photoshop, it gives more options. The image was 0.6º tilted to the left too In the past we would tilt the enlarger head and paper holder to get these effects . 1 Link to post Share on other sites More sharing options...
HowardMCheng Posted January 10, 2022 Share #5 Posted January 10, 2022 I see @jaapv has already identified the issue for you, but will also just add that the artificial horizon is pretty handy if you want to make sure your camera is level, as it has pitch sensor too as well as roll sensor. Although that is all well and good only if the buildings are perfectly straight. If you're shooting in an area with older architecture where subsidence has already caused some of the buildings to lean, it will be pointless, and you might as well just roll with it (see what I did there LOL). Hope that gives you some additional food for thought, @Lawly. H 2 Link to post Share on other sites More sharing options...
