Critique Required
ctb
I would lighten up the castle a bit in photoshop. It is the centrepiece and looks a bit too shadowy to me.
Andy is right, black point and levels, maybe some curve adjustment.
Also I would have a look at colourbalance, it seems to me to have a bit of green cast in the shadows.
Another nice trick is to use USM at radius 50 and threshold 0 maybe 100-150% to bring out the detail. This enhances microcontrast.
This picture is worth some work :)
OK, Jaap, Andy, Pete, Chuck & Stuny, thanks for your comments, I am no technophobe, but all these comments about USM's and curve adjustments and checking my levels are way over my head, PS elements is a mystery to me, but I have had another go, is this version any better.
Chris
Chris
These days, a little knowledge of PS is essential to get the best from your shits, I'm afraid.
Curves is included in PSE now, IIRC
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Chris
In that case I strongly recommend the purchase of Photoshop Elements 5 and the Scott Kelby book to go with it. The VLux1 is a great camera, but the files do often require post-processing to get the best results. This shot proves you've got a good eye, and that deserves the best prints... If you post the original file on yousendit.com, some of us could play around with it, if you like.
[ATTACH]52811[/ATTACH] HI I made a selection around the castle and made a slight adjustment to the levels I did the same to the sky then a small adjustment to the curves
and a small amount of unsharp mask hope this helps. regards mick.
