Gobert Posted November 28, 2021 Share #1 Posted November 28, 2021 Advertisement (gone after registration) I forgot to dismount my yellow filter when changing from M10M to M10R. Now I am looking to a yellow world and even worse, the wife is very disappointed in my skills… Is there a solution in LR (latest version)? Link to post Share on other sites More sharing options...
Advertisement Posted November 28, 2021 Posted November 28, 2021 Hi Gobert, Take a look here Good lord, I forgot my yellow filter…. any solution in LR?. I'm sure you'll find what you were looking for!
wda Posted November 28, 2021 Share #2 Posted November 28, 2021 (edited) Select all files and then find a file containing a neutral grey tone. Press 'W' and sample that tone with the eye-dropper. That should give you a basis for fine-tuning, if needed. It should remove the yellow cast. If you do not like the results, retrace your steps in the history panel. My advice is based on my experience with LR 6.4 Edited November 28, 2021 by wda 3 Link to post Share on other sites More sharing options...
Jeff S Posted November 29, 2021 Share #3 Posted November 29, 2021 Correct white balance first and sync adjustments across pics. Three simple ways, each of which will essentially add blue to counteract yellow. Jeff Link to post Share on other sites More sharing options...
erudolph Posted November 29, 2021 Share #4 Posted November 29, 2021 (edited) This suggestion comes from my career as a film and video colorist: In Lightroom, using the histogram for feedback, you can use the Color Grading module to refine and tweak your color balance. The first shot below is a crop of a blue sky. Looking at the right end of the histogram you can see the different proportions of R, G and B present in the upper midtones and highlights. Try using the Color Grading tools to get those curves as close to each other as possible, thus making it "whiter." That said, using the W color balance eye dropper to click on something neutral but not over or underexposed (i.e., not clipped) will give you a good head start. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 29, 2021 by erudolph 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/327011-good-lord-i-forgot-my-yellow-filter%E2%80%A6-any-solution-in-lr/?do=findComment&comment=4322382'>More sharing options...
jaapv Posted November 29, 2021 Share #5 Posted November 29, 2021 18 hours ago, Gobert said: I forgot to dismount my yellow filter when changing from M10M to M10R. Now I am looking to a yellow world and even worse, the wife is very disappointed in my skills… Is there a solution in LR (latest version)? Whatever solution you choose, you may get the gray neutral, but there is no way to restore the red/green balance in LR. An option might be to shoot a Passport profile with the yellow filter on and apply that. Link to post Share on other sites More sharing options...
Gobert Posted November 29, 2021 Author Share #6 Posted November 29, 2021 (edited) 4 minutes ago, jaapv said: Whatever solution you choose, you may get the gray neutral, but there is no way to restore the red/green balance in LR. An option might be to shoot a Passport profile with the yellow filter on and apply that. Or ask the wife to re-shoot her bikini photo’s. Edited November 29, 2021 by Gobert Link to post Share on other sites More sharing options...
wda Posted November 29, 2021 Share #7 Posted November 29, 2021 Advertisement (gone after registration) 52 minutes ago, jaapv said: Whatever solution you choose, you may get the gray neutral, but there is no way to restore the red/green balance in LR. An option might be to shoot a Passport profile with the yellow filter on and apply that. Getting the gray tones neutral removes colour contamination throughout the image. Leaves will not escape the correction. Link to post Share on other sites More sharing options...
jaapv Posted November 29, 2021 Share #8 Posted November 29, 2021 One would think so, but from practical experience: as soon as you neutralize gray you have red and green wrong. . Try it. It might be possible to correct in LAB, as the problem is caused by RGB linking colour and luminance. Link to post Share on other sites More sharing options...
jaapv Posted November 29, 2021 Share #9 Posted November 29, 2021 4 minutes ago, jaapv said: From practical experience: as soon as you neutralize gray you have red and green wrong. . Try it. It might be possible to correct in LAB, as the problem is caused by RGB linking colour and luminance. Link to post Share on other sites More sharing options...
wda Posted November 29, 2021 Share #10 Posted November 29, 2021 Jaap, correcting WB is global. If greens do not accord with your memory of the colour, you can tweak the hue by sampling a typical leaf, with the eye-dropper, until you get nearer your match. Of course, shooting a new profile for camera/lens combination, also helps in the future. Link to post Share on other sites More sharing options...
jaapv Posted November 29, 2021 Share #11 Posted November 29, 2021 You are thinking too simplistic. I'll try and find my example -quite a while back- or try it out yourself. The problem is that in removing the cast the colour of everything beyond blue-yellow gets shifted as well, which is what you mean, but as this is done in RGB, you lose the relative luminosity of red en green. That was also the reason that a simple magenta correction in unfiltered M8 files didn't work (and that Leica couldn't solve the problem in firmware). The blacks and greys were shifted to green and cyan as soon as one removed the magenta cast. Link to post Share on other sites More sharing options...
dewittehd Posted November 29, 2021 Share #12 Posted November 29, 2021 You might try this, works for me most of the time https://digital-photography-school.com/use-lab-color-photoshop-remove-unwanted-color-cast/ 1 Link to post Share on other sites More sharing options...
wda Posted November 29, 2021 Share #13 Posted November 29, 2021 11 minutes ago, jaapv said: You are thinking too simplistic. I'll try and find my example -quite a while back- or try it out yourself. The problem is that in removing the cast the colour of everything beyond blue-yellow gets shifted as well, which is what you mean, but as this is done in RGB, you lose the relative luminosity of red en green. That was also the reason that a simple magenta correction in unfiltered M8 files didn't work (and that Leica couldn't solve the problem in firmware). The blacks and greys were shifted to green and cyan as soon as one removed the magenta cast. Changing Hue is far from simplistic. Link to post Share on other sites More sharing options...
jaapv Posted November 29, 2021 Share #14 Posted November 29, 2021 Exactly, and that is what you would need to do for a shift as drastic as a yellow filter. Link to post Share on other sites More sharing options...
