ColinGrandhomme Posted November 20, 2021 Share #1 Posted November 20, 2021 Advertisement (gone after registration) I searched and could not find similar topics. I use both Capture One and DxO and shoot RAW only. Each program supposedly uses the Q2 to render its lens and colors properly but they look different. What is the consensus on which program(s) and/or settings bring out the best and most natural colors in the Q2? Thank you! Link to post Share on other sites More sharing options...
Advertisement Posted November 20, 2021 Posted November 20, 2021 Hi ColinGrandhomme, Take a look here Software and Color Rendering For Q2? . I'm sure you'll find what you were looking for!
jaapv Posted November 20, 2021 Share #2 Posted November 20, 2021 Welcome . Use the software you are most comfortable with. What you are seeing are the standard default settings of your programs. Easy enough to tweak the defaults to your taste to get your preferred colours out of any program. To get the most neutral default. use Lightroom and make a profile.But you might not like it and tweak it... Link to post Share on other sites More sharing options...
PhotoCruiser Posted November 20, 2021 Share #3 Posted November 20, 2021 There are several treads (including from me) regarding different color rendering by Photoshop/Lightroom/Capture One/etc When I switched from Lightroom to Capture One because a now solved problem with Lightroom the color rendering difference was rather big. Changing the import settings of Capture One solved that difference. As jaapv already wrote, use the one you are familiar with and tweak the import settings that the software in use renders "right" If you wanna be picky then you may use a calibration device able to calibrate your monitor and printer. Chris Link to post Share on other sites More sharing options...
jaapv Posted November 20, 2021 Share #4 Posted November 20, 2021 And profile your camera in your software... Link to post Share on other sites More sharing options...
