Photoworks Posted November 12, 2023 Share #21 Posted November 12, 2023 Advertisement (gone after registration) On 11/11/2023 at 7:39 AM, Bruno F. said: I hate to be that guy, but I'm a working photographer that recently switched to Leica SL system. I was planing to upgrade my SL to the SL2 and Leica lens (currently I'm using Lumix S series lens), but these minor issues are crucial to my workflow. It's a shame such basic features present on all the other brands are missing on Leica. I expected being able to have options for achieving my results rather than be told by some Leica fan that I should just "buy a Leica flash" since it is really not suited to my work. I really, really want to like Leica, but things keeps adding up. I buy a camera to make my life easier, not difficult. was there a question? Link to post Share on other sites More sharing options...
Advertisement Posted November 12, 2023 Posted November 12, 2023 Hi Photoworks, Take a look here high speed flash?. I'm sure you'll find what you were looking for!
Bruno F. Posted November 22, 2023 Share #22 Posted November 22, 2023 On 11/11/2023 at 11:31 AM, Virob said: Both godox and profoto released flash triggers for the SL2 about a year ago that support HSS. You might have to check which of their flashes are supported and possibly update the flash firmware. Will check that, thank you! Link to post Share on other sites More sharing options...
Bruno F. Posted November 22, 2023 Share #23 Posted November 22, 2023 On 11/12/2023 at 11:27 AM, Photoworks said: was there a question? I don't care. Link to post Share on other sites More sharing options...
JohnathanLovm Posted November 22, 2023 Share #24 Posted November 22, 2023 For AD600pro you need the X-Pro II (L) trigger. While HSS is working, the TTL is very bad results. Link to post Share on other sites More sharing options...
Pelu2010 Posted November 29, 2023 Share #25 Posted November 29, 2023 Also Godox strobes and speedlight work with the xpro 2 L trigger. ttl works and hss too. check it out Link to post Share on other sites More sharing options...
Bruno F. Posted December 9, 2023 Share #26 Posted December 9, 2023 On 11/22/2023 at 8:40 PM, JohnathanLovm said: For AD600pro you need the X-Pro II (L) trigger. While HSS is working, the TTL is very bad results. On 11/29/2023 at 12:03 PM, Pelu2010 said: Also Godox strobes and speedlight work with the xpro 2 L trigger. ttl works and hss too. check it out Sorry my late reply. I got the X-Pro II, but HSS is not working. Am I missing something? Thank you! Link to post Share on other sites More sharing options...
Pelu2010 Posted December 9, 2023 Share #27 Posted December 9, 2023 Advertisement (gone after registration) 42 minutes ago, Bruno F. said: Sorry my late reply. I got the X-Pro II, but HSS is not working. Am I missing something? Thank you! Don’t know ? How are you implementing it? Which stone or speedlight ? Ad 200 ad 100 v 1 is the latest firmware on the strobe speedlight? when the old firmware was on the flash it didn’t work (hss) cheers Link to post Share on other sites More sharing options...
Bruno F. Posted December 9, 2023 Share #28 Posted December 9, 2023 24 minutes ago, Pelu2010 said: Don’t know ? How are you implementing it? Which stone or speedlight ? Ad 200 ad 100 v 1 is the latest firmware on the strobe speedlight? when the old firmware was on the flash it didn’t work (hss) cheers Just checked, my X-Pro II is updated (v 1.4), but my AD400Pro is outdated (v 1.3). Updating Godox hardware is a pain with my Macbook, but this must be the reason is not working the HSS. I'll find a way to address that, thank you! Link to post Share on other sites More sharing options...
JohnathanLovm Posted December 10, 2023 Share #29 Posted December 10, 2023 13 hours ago, Bruno F. said: I got the X-Pro II, but HSS is not working. Do your Xpro II is Leica version? My HSS work as intended with AD100Pro, AD300Pro and AD600Pro. Are you connecting with non-HSS such as AD600BM? Link to post Share on other sites More sharing options...
Bruno F. Posted December 10, 2023 Share #30 Posted December 10, 2023 4 hours ago, JohnathanLovm said: Do your Xpro II is Leica version? My HSS work as intended with AD100Pro, AD300Pro and AD600Pro. Are you connecting with non-HSS such as AD600BM? Yes, is the L (Leica) version. I'm flashing the AD400Pro. I'll have to update and try again to see if it works. Link to post Share on other sites More sharing options...
Pelu2010 Posted December 10, 2023 Share #31 Posted December 10, 2023 18 hours ago, Bruno F. said: Just checked, my X-Pro II is updated (v 1.4), but my AD400Pro is outdated (v 1.3). Updating Godox hardware is a pain with my Macbook, but this must be the reason is not working the HSS. I'll find a way to address that, thank you! Yes, I found that it depends on the usbc cable you use. Some cable work better then other. if you know somebody that has a pc, maybe that make the process less painfull. but without the formalste update it does not work. I checked yesterday and even ttl works now perfectly …. Cheers 1 Link to post Share on other sites More sharing options...
Bruno F. Posted December 10, 2023 Share #32 Posted December 10, 2023 1 hour ago, Pelu2010 said: Yes, I found that it depends on the usbc cable you use. Some cable work better then other. if you know somebody that has a pc, maybe that make the process less painfull. but without the formalste update it does not work. I checked yesterday and even ttl works now perfectly …. Cheers Thanks for checking. I'll definitely find a way to perform this update. 👍 Link to post Share on other sites More sharing options...
Geoff C. Bassett Posted August 4, 2024 Share #33 Posted August 4, 2024 On 12/10/2023 at 2:04 PM, Bruno F. said: Thanks for checking. I'll definitely find a way to perform this update. 👍 Did you ever try it out with the update? Link to post Share on other sites More sharing options...
