matt.tyler Posted August 11, 2021 Share #1 Posted August 11, 2021 Advertisement (gone after registration) Hi, I have a question: how can I find out what model number a lens has by serial number and year? Summilux-M 1.4/35mm Known serial: 3 282 xxx Thanks Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 11, 2021 Posted August 11, 2021 Hi matt.tyler, Take a look here serial and model number. I'm sure you'll find what you were looking for!
a.noctilux Posted August 11, 2021 Share #2 Posted August 11, 2021 First approximation ...in Wiki https://www.l-camera-forum.com/leica-wiki.en/index.php/35mm_f/1.4_Summilux_II ... 3281401 3282400 35mm f/1.4 Summilux-M (ELC.black) 1983 1000 Quote Link to post Share on other sites More sharing options...
matt.tyler Posted August 12, 2021 Author Share #3 Posted August 12, 2021 Thank you, I had also found that. But then how do I get further to the model number? Quote Link to post Share on other sites More sharing options...
adan Posted August 12, 2021 Share #4 Posted August 12, 2021 Which model number do you mean? It is a so-called Version II (see link title in post #2), but also (if the wiki is correct) black anodized, which gives it a catalog number of 11870. Also, if you don't already know, Leica pre-assigned S/Ns in blocks: "The next 1000 35mm Summiluxes we make will get numbers 3281401 through 3282400" That block of numbers was not used up and replaced with a new block until 1985, so it may be a 1983 or a 1984 (or even possibly an early 1985) lens. (In other words, Leica serial numbers sometimes have to be read like animal entrails ) But in any case a version II (2), and a 11870 black lens. Quote Link to post Share on other sites More sharing options...
matt.tyler Posted August 12, 2021 Author Share #5 Posted August 12, 2021 vor 18 Minuten schrieb adan: Which model number do you mean? It is a so-called Version II (see link title in post #2), but also (if the wiki is correct) black anodized, which gives it a catalog number of 11870. Also, if you don't already know, Leica pre-assigned S/Ns in blocks: "The next 1000 35mm Summiluxes we make will get numbers 3281401 through 3282400" That block of numbers was not used up and replaced with a new block until 1985, so it may be a 1983 or a 1984 (or even possibly an early 1985) lens. (In other words, Leica serial numbers sometimes have to be read like animal entrails ) But in any case a version II (2), and a 11870 black lens. Yes, thank you...that's what I meant, catalog number 11870. Is there any complete listing for this as well? Quote Link to post Share on other sites More sharing options...
adan Posted August 12, 2021 Share #6 Posted August 12, 2021 You mean a list of all the catalog numbers (or the 5-letter codes that preceded them) - cross-referenced to the items in detail? The Leica wiki has a lot, but subdivided by categories, so you have to hunt around a bit from section to section. http://www.l-camera-forum.com/leica-wiki.en/index.php/Main_Page For example: http://www.l-camera-forum.com/leica-wiki.en/index.php/M_Lenses_x_Focal_Length or http://www.l-camera-forum.com/leica-wiki.en/index.php/E Other than that, the only ones I know of are in collectors' reference books, and even then you have to have some idea of what you are looking for. Although there is this: https://stephen-westin.com/misc/Leica_order_numbers.html You might ask on the Historica/Collectors sub-Forum. Quote Link to post Share on other sites More sharing options...
jensthoes Posted August 12, 2021 Share #7 Posted August 12, 2021 Advertisement (gone after registration) ...best for this information: http://www.summilux.net/numeros/index.php?sid=7f0b5e7b2b517f9dd72e199be2b4741d Best, Jens 1 Quote Link to post Share on other sites More sharing options...
a.noctilux Posted August 12, 2021 Share #8 Posted August 12, 2021 2 hours ago, jensthoes said: ...best for this information: http://www.summilux.net/numeros/index.php?sid=7f0b5e7b2b517f9dd72e199be2b4741d Best, Jens Not really, I use this for very long, but infos are very sparse and very variable or incomplete. as I've asked years ago for my Summilux Ti coated 35mm : we have in this only valable year of production and nothing more than that even the type is not "seen" ! [ Entrez le numéro de série et indiquez si il concerne un boîtier ou un objectif. Type de matériel : Numéro de série : L'objectif portant le numéro de série 3602424 est ? fabriqué en 1992 ] this one at right Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/323494-serial-and-model-number/?do=findComment&comment=4255476'>More sharing options...
jensthoes Posted August 13, 2021 Share #9 Posted August 13, 2021 ….this website is fine for the age of cameras and lenses in the last century. For newer stuff it is not complete. Best, Jens Quote Link to post Share on other sites More sharing options...
Guest Posted August 13, 2021 Share #10 Posted August 13, 2021 (edited) On 8/12/2021 at 3:23 PM, matt.tyler said: Yes, thank you...that's what I meant, catalog number 11870. Is there any complete listing for this as well? https://www.lindemanns.de/shop/fotobuchhandlung/64182l-hartmut-thiele--leitz-leitz-leica-bestellkatalog-1925-2012.php Not complete and not without errors but the best we have. If this were online it could be searched much more conveniently. The same author also has published an extensive list of lens production dates: https://www.lindemanns.de/shop/fotobuchhandlung/64181l-leica--hartmut-thiele-grosses-fabrikationsbuch-leica-objektive.php Edited August 13, 2021 by Studienkamera Quote Link to post Share on other sites More sharing options...
a.noctilux Posted August 13, 2021 Share #11 Posted August 13, 2021 This is precious, Tech Data - Erwin Puts (2002) Leica M-Lenses.pdf - pgs. 34 - 37 Quote Link to post Share on other sites More sharing options...
