N J Ducassi Posted August 6, 2021 Share #1 Posted August 6, 2021 Advertisement (gone after registration) A brand new SL2-s display became totally grainy while focusing. Then it was ok, this happened twice. It was just grainy texture not a grainy image. Has anyone experienced this? Link to post Share on other sites More sharing options...
Advertisement Posted August 6, 2021 Posted August 6, 2021 Hi N J Ducassi, Take a look here SL2-s display goes grainy while focusing. I'm sure you'll find what you were looking for!
michali Posted August 7, 2021 Share #2 Posted August 7, 2021 (edited) 6 hours ago, N J Ducassi said: A brand new SL2-s display became totally grainy while focusing. Then it was ok, this happened twice. It was just grainy texture not a grainy image. Has anyone experienced this? Welcome to the Forum. Is your Focus Peaking on & set to White? This can give the appearance of grainy texture. Edited August 7, 2021 by michali Link to post Share on other sites More sharing options...
N J Ducassi Posted August 7, 2021 Author Share #3 Posted August 7, 2021 Hi Thank you for your reply. I had focus peaking on red, I was trying to focus on low light conditions when the screen became all grain no image, then it was ok Link to post Share on other sites More sharing options...
michali Posted August 7, 2021 Share #4 Posted August 7, 2021 (edited) 1 hour ago, N J Ducassi said: Hi Thank you for your reply. I had focus peaking on red, I was trying to focus on low light conditions when the screen became all grain no image, then it was ok Since my reply to you, coincidentally & strangely I had the same issue about 1 hour ago. After changing lenses & as I was trying to focus indoors, the screen went all red & grain . I turned the camera off & on again it was OK. Very odd, I've had my SL2-S for 6 weeks & this is the 1st time it's happened. I had a similar issue with my CL, where the screen went all grainy when playing back images, that turned out to be the SD card. Edited August 7, 2021 by michali Link to post Share on other sites More sharing options...
Photoworks Posted August 7, 2021 Share #5 Posted August 7, 2021 21 minutes ago, michali said: grainy when playing back images, that turned out to be the SD card. Film grain on SD card Link to post Share on other sites More sharing options...
N J Ducassi Posted August 7, 2021 Author Share #6 Posted August 7, 2021 3 hours ago, michali said: Since my reply to you, coincidentally & strangely I had the same issue about 1 hour ago. After changing lenses & as I was trying to focus indoors, the screen went all red & grain . I turned the camera off & on again it was OK. Very odd, I've had my SL2-S for 6 weeks & this is the 1st time it's happened. I had a similar issue with my CL, where the screen went all grainy when playing back images, that turned out to be the SD card. Thanks for this info. I had the same SD card for weeks, but maybe is a good idea to change it. I did try to contact Leica tech support in vain, they don’t answer emails or phone calls. Did you ever contact them successfully? Link to post Share on other sites More sharing options...
Ba Erv Posted August 7, 2021 Share #7 Posted August 7, 2021 (edited) Advertisement (gone after registration) Lens? Focus Settings? EVF refresh rate? I’ve had a few issues with my SL2-S and the Sigma Contemporary lenses when using Spot focus. In fact, in Spot focus and hitting the magnification button will lock the camera up completely. Only removing the battery will reset the camera. Edited August 7, 2021 by Ba Erv Link to post Share on other sites More sharing options...
michali Posted August 7, 2021 Share #8 Posted August 7, 2021 1 hour ago, N J Ducassi said: Thanks for this info. I had the same SD card for weeks, but maybe is a good idea to change it. I did try to contact Leica tech support in vain, they don’t answer emails or phone calls. Did you ever contact them successfully? If you don't already have SD Card Formatter, download it here SD Memory Card Formatter , reformat your card & see what happens. I've reformatted both cards & see if the issue repeats. Good luck trying to get hold of Leica tech support. I normally deal with the Customer Service Dept. in Germany, they're responsive & helpful. Link to post Share on other sites More sharing options...
N J Ducassi Posted August 7, 2021 Author Share #9 Posted August 7, 2021 Thanks. I will keep posting on this issue. Let me know if the solution worked on your end. And thanks for the tip about customer service in Germany. 1 Link to post Share on other sites More sharing options...
michali Posted August 7, 2021 Share #10 Posted August 7, 2021 (edited) 41 minutes ago, Ba Erv said: Lens? Focus Settings? EVF refresh rate? I’ve had a few issues with my SL2-S and the Sigma Contemporary lenses when using Spot focus. In fact, in Spot focus and hitting the magnification button will lock the camera up completely. Only removing the battery will reset the camera. Thanks for sharing. I had the 65m f2 Sigma DG DN mounted on the camera & Spot Focus when this happened. I've tried to replicate it based on your info. but all OK so far. Try another SD card, this sounds exactly like my issue with the CL which I mentioned in post #4 above. If that doesn't work, it may possibly have something to do with mounting the lens so that it locks fully into place. I've previously had a black screen on the SL2 after mounting Sigma lenses- solved by removing & remounting the lens with a firmer twist. Edited August 7, 2021 by michali Link to post Share on other sites More sharing options...
Ba Erv Posted August 7, 2021 Share #11 Posted August 7, 2021 33 minutes ago, michali said: Thanks for sharing. I had the 65m f2 Sigma DG DN mounted on the camera & Spot Focus when this happened. I've tried to replicate it based on your info. but all OK so far. Try another SD card, this sounds exactly like my issue with the CL which I mentioned in post #4 above. If that doesn't work, it may possibly have something to do with mounting the lens so that it locks fully into place. I've previously had a black screen on the SL2 after mounting Sigma lenses- solved by removing & remounting the lens with a firmer twist. Mine was hit and miss also. The 45mm and 24mm would do the lock up occasionally but the 35mm was fine. Maybe it’s just something with the contacts slightly out of alignment. Link to post Share on other sites More sharing options...
N J Ducassi Posted August 7, 2021 Author Share #12 Posted August 7, 2021 55 minutes ago, michali said: Thanks for sharing. I had the 65m f2 Sigma DG DN mounted on the camera & Spot Focus when this happened. I've tried to replicate it based on your info. but all OK so far. Try another SD card, this sounds exactly like my issue with the CL which I mentioned in post #4 above. If that doesn't work, it may possibly have something to do with mounting the lens so that it locks fully into place. I've previously had a black screen on the SL2 after mounting Sigma lenses- solved by removing & remounting the lens with a firmer twist. 1 hour ago, Ba Erv said: Lens? Focus Settings? EVF refresh rate? I’ve had a few issues with my SL2-S and the Sigma Contemporary lenses when using Spot focus. In fact, in Spot focus and hitting the magnification button will lock the camera up completely. Only removing the battery will reset the camera. Hi I was using an M lens when it happened and spot focus. Thanks for the info. Hopefully it won’t happen again after the reset. When I call the Miami Leica store I was told they’ve never seen this, very frustrating. That’s usually the answer. So is good to get feedback from other users. Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 7, 2021 Share #13 Posted August 7, 2021 (edited) This has been reported several times here, and I think it was understood to be an intentional design issue, even if not a very satisfactory one. The notion is that while the processor puts all its energy into focusing it reduces the EVF resolution a bit to help keep the refresh rate brisk. This happens when focusing by Contrast Detect is difficult (low light or little contrast to detect), so it doesn't happen all the time. It's not something I have noticed, but that might be because when focusing is a struggle due to low light the image is a bit blurred anyway, so I'm not noticing anything different. Now the matter has been brought up again I'll probably see it all the time😉. Edit. Just read that you were using a M lens, not an AF lens - the issue I referred to was during AF - and I have no other suggestion to offer🤔 Edited August 7, 2021 by LocalHero1953 1 Link to post Share on other sites More sharing options...
