fishdrummer1 Posted August 2, 2021 Share #1 Posted August 2, 2021 Advertisement (gone after registration) My M9 is due for a ccd fix. I also have a Monochrome which I love. has anyone used maxmax for ccd repair? https://maxmax.com/maincamerapage/monochrome-cameras/leica-monochrome/leica-m9 I was thinking of converting it to monochrome? dumb idea for the cost? Thanks We can offer the following conversion options: 1: Replace the defective ICF with a new ICF leaving the camera as a color camera: $1,500 2: Replace the defective ICF with a UV-VIS-IR window making the camera into a full spectrum color camera: $1,500. Note that with this conversion, you will generally want to use a filter on your lens. For visible light pictures, you would use our UV and IR blocking XNiteCC1 filter. If you wanted to take an IR picture, you could use a variety of IR longpass and bandpass filters. If you wanted to take a UV picture, you would use a UV shortpass filter. We have hundreds of filter options in diameters from 25mm to 82mm. 3: Replace the defective ICF with a new ICF and change the sensor to monochrome: $2,500 4: Replace the defective ICF with a UV-VIS-IR windows making the camera into a full spectrum monochrome camera : $2,500. UV sensitivity will be about 6x greater than leaving the camera as a color camera. Again, you would generally be using filters on your lens depending on what type of light you want the camera to see. Link to post Share on other sites More sharing options...
Advertisement Posted August 2, 2021 Posted August 2, 2021 Hi fishdrummer1, Take a look here M9 maxmax Monochrome conversion??. I'm sure you'll find what you were looking for!
JonPB Posted August 2, 2021 Share #2 Posted August 2, 2021 I would only convert to monochrome if I could also load the Monochrom firmware. When last I looked, realizing the benefits of a monochrome sensor with firmware/software that expects a Bayer filter requires dumping the raw data manually, e.g. into a 16-bit TIFF, before processing; but then the tools that work specifically with raw data will reject those files as being already interpolated. Nothing prohibitive but a lot of headache, all of which would go away on an M9 with Monochrom firmware. I think they do that? Best to check. I used to have both a Monochrom and M9. Having color as an option is nice even in an all-B&W workflow: for adjusting luminance by color, correcting lateral chromatic aberrations before B&W conversion, recovering blown highlights, having a lower base sensitivity for wider-aperture shooting, or just being able to share snapshots with folks who expect color. But there is a lot of convenience in having functionally identical cameras, too. Link to post Share on other sites More sharing options...
Daniel H. L Posted August 2, 2021 Share #3 Posted August 2, 2021 I just found this last night. Please see the link below. I hope it helps. https://www.rangefinderforum.com/forums/showthread.php?t=174228 1 Link to post Share on other sites More sharing options...
