kamek Posted May 21, 2021 Share #1 Â Posted May 21, 2021 Advertisement (gone after registration) Hi all, I'm wondering how you're supposed to use the in-camera meter (I'm shooting on an MP) when using an ND filter. For example, if I'm using Portra 400 with a 0.9 ND filter, do I: 1. Leave the meter at 400 ISO and let the TTL meter read as usual 2. Adjust the meter to 160 ISO since the ND filter is 3-stops? Thanks in advance! Link to post Share on other sites More sharing options...
Advertisement Posted May 21, 2021 Posted May 21, 2021 Hi kamek, Take a look here How to meter when using ND filter?. I'm sure you'll find what you were looking for!
a.noctilux Posted May 21, 2021 Share #2  Posted May 21, 2021 1. 😉 miracle of TTL metering ( you already know that ! ) 1 Link to post Share on other sites More sharing options...
250swb Posted May 22, 2021 Share #3 Â Posted May 22, 2021 Use the camera's meter, the only consideration is that the MP can only meter to 1 second so anything longer and you'd need a hand held meter set to 50 ISO. Any exposures longer than 1 second you then have to take into account the reciprocity of the film and increase exposure. Link to post Share on other sites More sharing options...
Anakronox Posted May 31, 2021 Share #4  Posted May 31, 2021 Just an alternative if you happen to be carrying your smartphone and not a handheld meter.  You can meter without the ND and then use an exposure calculator such as Photopills.  The advantage to that is it has a timer coupled with the calculator so when setting your shutter speed to bulb, you know exactly when to let off the cable release. As 250swb mentioned be aware of reciprocity failure and account for that.  Link to post Share on other sites More sharing options...
