To expand on Adam's reply... the raw file will always contain the data captured by the image sensor which in the case of the M 262 is data filtered by a a color Bayer array.   Your image processing software will likely see that as a color image.  Some software may notice that you asked for B&W -- saturation set to B&W in the JPEG settings -- and convert the image to B&W for you.
If you want B&W out of the camera you'll need to set the File format to JPEG or DNG+JPEG and use the jpeg files created by the camera.
It seems that I didn't find in my french manual either.
I never used the Monochrom jpeg from the M262, having the real thing as Monochrom (only ! ).
Found how to do it, a bit tricky, not really logical:
- in Menu - JPG Settings, Saturation then B&W (last line) , set
- SET button - File Format , JPG fine or DNG + JPG Fine
For "learner" (as I was, it can be used as guide for better B&W).
It WAS useful for me to see on LCD how the subject WOULD show in B&W.
With M262 without liveview, only way to go after taking the pic.
Or if B&W in later post PP can be planned.
