Seeing more images, it makes me think it’s something to do with a sensor readout problem where some data is getting corrupted while the data is being read from the sensor. It could be something else on the board like a bad internal connector, or even potentially a bad memory card. It’d be worth testing with a different memory card to rule that out. If it’s not the memory card, it’ll likely need to go to Wetzlar.
yeah it was a new card i'd never used. im going to try the old trusted cards for a bit and see what happens. thanks for your help.
I see this sometimes on my X-Rays (without the distortion correction, obviously). It is a buffer-memory problem when writing the file. I fear that it is a job for Wetzlar, but send them a few files to evaluate first.
thanks. is the quickest path sending to the tech people in new jersey first?
I have see this problems with Lexar cards. Changed card and it went away. I would do more testing before sending it in.
From the USA it is best to send to NJ. they will take care of all the costly shipment and import export paper. My understanding is that they don't do any repair of SL cameras and lenses anywhere else then Germany.
You should aspect a 3 month turnaround time
thanks. the card in question was a new SanDisk card. So far i have had no more issues. I suspect it was the card but will continue to monitor. Thanks for your help.
I had a similar problem (only with two files). I happened to write to both sd cards (both of them raw) and the file on the other card was fine.
this let’s me believe it’s a problem with the card. Can you try to shoot raw to both cards and check whether you see this line on both copies?
I had a very similar problem when my SL2 was brand new and it was a brand new SanDisk card.  Swapped for another identical new card and the problem disappeared and has never returned.  I heaved a huge sigh of relief!  I wish you the same easy fix.
Kent
This is a data write problem, it happens when the processor if "offloading" the data to the memory card. Whether it's a processor, or a card problem, is difficult to say, but in 95% of cases the cause for this error is the card. I believe the problem will dissapear with replacing the memory card.
