What does it  mean when my SL Battery Charger Orange and Green Legs fast blink at same time?
If I unplug charger and plug back in seems to charge like normal but this keeps happening.
Is there an issue with battery or is it SL battery Charger?
Rapid flashing of the two LEDs (> 2 Hz) when charging commences indicates a charging error (e.g. maximum charging time exceeded, voltages or temperatures outside permitted ranges or a short circuit). Disconnect the charger from the mains and remove the battery. Ensure that the above tempera- ture conditions are met and then restart the charging process.
8 hours ago, stump4545 said:
40-45degrees kinda of cold maybe ambient temperature effecting charger.
Cold and hot temps can cause problems with charging. Neither extremes are a good idea. Some chargers will prevent charging when the battery cell exceeds preset temperature limits.
