I know M10P is probably not the best macro platform, but I have thrown together some info (I hope it is correct) to assist with lens selection.
I have a Nisi 58mm close up filter which has a diopter factor of 5x and I have ordered the Macro M Adaptor (waiting, waiting, waiting).  Leica Elpro is 7x diopter btw.
So I thought I would save a lot of experimentation and factor in some macro equations for some glass I have.  If I gave any figures wrong, please let me know.
Maybe later I will play with the R macro glass.
50mm f2 summicron, 0.7m close focus
Native reproduction ratio 1:11.5
With NISI alone 1:1.03
With macro adapter at 18mm 1:2.3
With macro adapter at 30mm 1:1.5
Both at 18mm 1:1.25
Both at 30mm 1:1.91
75mm f2.5 summarit, 0.7m close focus
Native reproduction ratio 1:7.2
With NISI alone 1:1.75
With macro adapter at 18mm 1:2.6
With macro adapter at 30mm 1:1.9
Both at 18mm 1:1.11
Both at 30mm 1:0.89
90mm f2 summicron, 0.9m close focus
Native reproduction ratio 1:9
With NISI alone 1:1.67
With macro adapter at 18mm 1:3.2
With macro adapter at 30mm 1:2.3
Both at 18mm 1:1.11
Both at 30mm 1:0.92
135mm f2.8 elmarit, 1.5m close focus
With NISI alone 1:1.23
With macro adapter at 18mm 1:4.1
With macro adapter at 30mm 1:3.0
Both at 18mm 1:0.93
Both at 30mm 1:1.23
What does this mean?
Best macro rig is the 75mm at 30mm with Nisi for 1:0.89 which is higher magnification than 1:1 which is a macro lens standard.  90mm and 135mm are close behind.  It is a huge advantage the 75 summarit is sharp as a tack.
I hope to share some examples from the rig with my M10P.
Comment only on the 2.5/75mm.
For me also, good surprise with this cheap 75mm,
I used the Summarit-M 2.5/75mm for close-up and using some Elpro/OUFRO/etc.
Out of curiosity, I try the 2.5/75 for slide "M-scanning", it's very good at 1:1 nothing I can complain comparing to other Focotar or macro SLR lenses.
In 3D world, plants or pics with some high light spots, some colored aberrations when I compare with the trusty Apo-Summicron-M 75mm.
But with Monochrom, this 2.5/75 is at top (even when I use colored filters no shift focus to talk about).
With a FotoDiox Nikon F to Leica M lens mount adapter, I can easily mount the following Nikon equipment on my M10 to obtain reproduction ratios much higher than 1:1
1. 55mm f/3.5 Nikkor macro lens
2. 105mm f/2.8 Nikkor macro lens
3. Nikon PB4 bellows
4. Nikon extension tubes
Edited by Narsuitus
Not a direct answer to your question, but I do (did) use the M10 for macro.  My main lens for this purpose is (was) the outstanding Apo Elmarit R 2.8 100 mm Macro.  This lens goes natively down to 1:2 at 45 cm and 1:1 with the Elpro at 30 cm mounted on the front. Focusing with the Visoflex on the M10 (or on my M10M) is workable, but not more than that.
I switched to the SL2 with the same R-lens and this made a whole difference.  I’m planning to add an external monitor mounted on top of the SL2 for more critical focusing.
Good luck.  Macro is fun and rewarding!
