Nash Posted January 28, 2021 Share #1  Posted January 28, 2021 Advertisement (gone after registration) Hi does anyone know how I can use a Nikon fb-700 from on top of hot shoe or from flash port hole , Ihave tried it on top and nothing the connection look same as Leica ,ðŸ¤Also tried plugging a lead in the side to side of flash but Nothing . will I have to get a studio Srobe and if so how would I sync that any HELP ðŸ¤ðŸ¤” Link to post Share on other sites More sharing options...
Advertisement Posted January 28, 2021 Posted January 28, 2021 Hi Nash, Take a look here Sl2s flash. I'm sure you'll find what you were looking for!
Jonathan Levin Posted January 28, 2021 Share #2 Â Posted January 28, 2021 I thought i read that the flash should work but in Manual mode. TTL exposure not applicable. I'd like to know this to since I have been think about this set up as well. Manual mode is fine with me though. Link to post Share on other sites More sharing options...
helged Posted January 29, 2021 Share #3  Posted January 29, 2021 On 28.1.2021 at 8:42 PM, Nash said: Hi does anyone know how I can use a Nikon fb-700 from on top of hot shoe or from flash port hole , Ihave tried it on top and nothing the connection look same as Leica ,ðŸ¤Also tried plugging a lead in the side to side of flash but Nothing . will I have to get a studio Srobe and if so how would I sync that any HELP ðŸ¤ðŸ¤” Just to confirm: Camera with mechanical shutter activated? (no flash with electronic shutter) Link to post Share on other sites More sharing options...
Photoworks Posted January 29, 2021 Share #4 Â Posted January 29, 2021 1 hour ago, helged said: Just to confirm: Camera with mechanical shutter activated? (no flash with electronic shutter)Â Correct only mechanical shutter. Link to post Share on other sites More sharing options...
Nash Posted January 30, 2021 Author Share #5  Posted January 30, 2021 13 hours ago, Photoworks said: Correct only mechanical shutter. Thanks but should screen flicker when a flash is connected Link to post Share on other sites More sharing options...
Photoworks Posted January 30, 2021 Share #6  Posted January 30, 2021 8 hours ago, Nash said: Thanks but should screen flicker when a flash is connected explain? do you have LED lighting in the room? Link to post Share on other sites More sharing options...
Nash Posted January 30, 2021 Author Share #7  Posted January 30, 2021 (edited) Advertisement (gone after registration) Hi no it flickers when I have a flash on hot shoe Nikon sb -700 is it possible to connect a lead into sl2 and then In to flash . I did try this with a sb 700 but nothing happens.seems like Leica don’t like flash units of other brands 🥶 Edited January 30, 2021 by Nash Link to post Share on other sites More sharing options...
Anakronox Posted January 31, 2021 Share #8  Posted January 31, 2021 Change your exposure preview mode from P-A-S-M to P-A-S to get rid of the screen flicker when using flash. Link to post Share on other sites More sharing options...
Nash Posted January 31, 2021 Author Share #9  Posted January 31, 2021 Thanks Link to post Share on other sites More sharing options...
bherman01545 Posted February 1, 2021 Share #10  Posted February 1, 2021 As with any non-dedicated flash, you're only working off of the center contact on the flash and camera's hotshoe. You would set the camera to manual, set the Shutter Speed to the correct Flash Synchronization Speed (in your case, it's 1/250 sec or less) and either turn the flash to Manual (which means that each corresponding distance requires a different F/Stop) OR, Set the correct ISO on the flash and then put the flash on Auto or "A", (but not TTL) In this scenario, when the flash is set to 'Auto' there are usually 1-4 Auto Ranges, wherein each Auto Range requires a specific F/Stop, and that F/Stop is good for the entire distance range - the circuitry in the flash (a-la the flash's sensor and NOT the camera sensor)  quenches the circuit and tells the flash when to cut-off. You'll need to test it, but I know that my simple Metz flash works great with three auto ranges as well as full manual control on the SL, SL2 and SL2-S Make sense? -Brad Link to post Share on other sites More sharing options...
Nash Posted February 4, 2021 Author Share #11  Posted February 4, 2021 Thanks again Link to post Share on other sites More sharing options...
