I tested a Leica 60mm f/2.8 ASPH with my Leica CL. I used A setting and when I adjusted to the largest aperture setting it wouldn't go no larger then f/3.4. I have the latest 4.0 firmware. I suspect the camera didn't read the lens metadata correctly. Anyone else seen this?
Edited by andben
spelling
Hi, Andben
  As i know, this lens has two working modes: Macro mode (max aperture: f/3.4) and normal mode (max aperture: f/2.8).
  The mode is selected automatically based on the focus distance.
  Please try to focus to infinity and check whether the aperture can be set to f/2.8.
Welcome. What aperture is recorded is an educated guess. There is no communication between lens and processor.
On 1/23/2021 at 4:56 PM, Leon Sung said:
Hi, Andben
I see, I didn't know that, then it would make sense. I don't own the lens just tested in store as I wanted to get it! Thanks so much for the answer
6 hours ago, andben said:
I think the behavior I saw might stem from the distance as some people pointed out. Time for another trip to the store to test theory. Thanks for your feedback!!!
I have this lens & Leon in post #3 above is correct. At macro distances, I guesstimate @ a distance of approx. 15cm to 20cm from the front of the lens it defaults to f3.4 & as you move further back it goes to f2.8.  The lens is designed this way & does this on both the CL & SL2.
It could be, that the f3.4 reported at short distances is the effective aperture. As the distance sensor - object gets shorter, (increasing aspect ratio) the distance lens - sensor gets bigger. This yields in an decrease of the illumination on the sensor. Leaving the aperture mechanical unchanged, to calculate the correct exposure time, a smaller aperture (higher f-stop) must be assumed: the 'effective' aperture. I know, that some Nikon macro lenses transfer the effective and not the 'real' aperture to the camera.
Ă—
Ă—
