TeleElmar135mm Posted December 6, 2020 Share #1  Posted December 6, 2020 Advertisement (gone after registration) Hi, I had a SL (601) for test at home. I had a problem with the EVF. The blacks look very bad. I can compare that with the look of a picture in Photoshop with Proof Setup on and a matte paper icc-profil. Also the numbers for time etc. are not white on black but white on grey to darkgrey. Never seen this with other cameras or in the brochure from Leica or in a threat here. On the rear monitor it looks quite good/normal, the black are black (also on raws and jpegs on the PC). So my question is: Is this a normal behavior or a damaged EVF? Link to post Share on other sites More sharing options...
Advertisement Posted December 6, 2020 Posted December 6, 2020 Hi TeleElmar135mm, Take a look here SL (601 - EVF. I'm sure you'll find what you were looking for!
ImmerDraussen Posted December 6, 2020 Share #2  Posted December 6, 2020 Hi, the contrast and brightness of the SL viewfinder falls back against the the lastet versions i. e in the S1R or the SL2. Especially outside it is pretty dark if you under expose the picture. A work around in these situations is to change the jpg settings. If you put the contrast to very low and the saturation to very high you get a brighter picture in the EVF. But of course, black becomes grey. As long as you stay in raw, the pictures are okay. So if it is not your camera, checking the jpg setting may help. The black frame  around the picture in the EVF should be black. Andreas Link to post Share on other sites More sharing options...
TeleElmar135mm Posted December 6, 2020 Author Share #3  Posted December 6, 2020 Thanks Andreas, the frame around the picture is not black. And the jpeg settings change helps nothing. The light condion (sunlight condition, cloudy or indoor) did not change the result: Blacks are looking like in light fog. And the EVF is not pretty dark. So I think there is a problem with the EVF  Michael Link to post Share on other sites More sharing options...
Chuck Albertson Posted December 6, 2020 Share #4 Â Posted December 6, 2020 Just to check - are you wearing sunglasses while shooting the SL? The polarizing layer in most sunglass lenses does not play well with the EVF. 1 Link to post Share on other sites More sharing options...
TeleElmar135mm Posted December 6, 2020 Author Share #5 Â Posted December 6, 2020 Sorry but no sunglases - the weather is not fine here. I checked it for a 2nd time and the EVF is not darker, he is brighter than the monitor on the back. Link to post Share on other sites More sharing options...
Photoworks Posted December 8, 2020 Share #6 Â Posted December 8, 2020 The SL has a tendency to get blue in the black parts of the EVF in some conditions. The EVF in the SL2 is OLED and has resolved this issue. If you are experiencing slight color and contrast shift in blacks, that is normal. If it more then it is a defective LCD light Link to post Share on other sites More sharing options...
TeleElmar135mm Posted December 8, 2020 Author Share #7 Â Posted December 8, 2020 Advertisement (gone after registration) Thanks Photoworks, I think it is a defective LCD-Screen. Another Camera was quiete "normal". Â Thanks Link to post Share on other sites More sharing options...
