Heilperc Posted November 21, 2020 Share #1 Posted November 21, 2020 Advertisement (gone after registration) Can someone please advise me on how to use the SL 601 with M lenses, specifically the 35mm summilux? I have the Leica adapter but I’m unsure of what settings to use. Thank you. Link to post Share on other sites More sharing options...
Advertisement Posted November 21, 2020 Posted November 21, 2020 Hi Heilperc, Take a look here Leica SL 601 with M lenses. I'm sure you'll find what you were looking for!
Ktsa5239 Posted November 21, 2020 Share #2 Posted November 21, 2020 It should automatically recognise the lens if you have the Leica adapter. No settings required, just shoot. 1 Link to post Share on other sites More sharing options...
Heilperc Posted November 21, 2020 Author Share #3 Posted November 21, 2020 Thank you! Link to post Share on other sites More sharing options...
Heilperc Posted November 22, 2020 Author Share #4 Posted November 22, 2020 I will try it again tomorrow and hopefully it will work as described. Thanks again. Link to post Share on other sites More sharing options...
Mr.Q Posted November 22, 2020 Share #5 Posted November 22, 2020 Does your Summilux have 6 bit coding? If not, the camera will not recognize the lens and you have to set it manually in camera. Link to post Share on other sites More sharing options...
Anakronox Posted November 22, 2020 Share #6 Posted November 22, 2020 If using the Leica adapter, your SL should be set to fully manual automatically, if I remember correctly. Link to post Share on other sites More sharing options...
scott kirkpatrick Posted November 22, 2020 Share #7 Posted November 22, 2020 Advertisement (gone after registration) 3 hours ago, Anakronox said: If using the Leica adapter, your SL should be set to fully manual automatically, if I remember correctly. Both M and A are available. 1 Link to post Share on other sites More sharing options...
Anakronox Posted November 22, 2020 Share #8 Posted November 22, 2020 1 hour ago, scott kirkpatrick said: Both M and A are available. Copy that. Thank you for correcting me. Link to post Share on other sites More sharing options...
Heilperc Posted November 22, 2020 Author Share #9 Posted November 22, 2020 Thank you. I’m seeing that A and M are both available. I appreciate all of your replies. Link to post Share on other sites More sharing options...
