Elmar 1:2.8/50mm collapsible from 1965 usable with M10?
According to the M10 manual some of the old lenses cannot be used, e.g. Hologon 15mm/f8 or the Elmar 90mm/f4. Other lenses have restrictions and there are risks to damage the camera. But what about the Elmar 1:2.8/50mm collapsible from 1965? As @farnz pointed out in another thread, there three differenz Elmar lenses:
Am 21.8.2020 um 03:16 schrieb farnz:
Just to clarify, Bob, there are three different 50mm Elmar-M lenses (in bayonet mount), all collapsible:
  • 50/3.5 Elmar-M (1953 -1962) Serial # 1,302 - 1,700,000
  • 50/2.8 Elmar-M (1957 - 1972) Serial # 1,402,001 - 2,503,100
  • 50/2.8 Elmar-M (1994 - 2007), Serial # 3,668,031 - n/a
Leica is quite conservative regarding such warnings.  Are you inquiring in regard to whether it is safe to collapse it into the camera or some other issue?
This thread, along with about a dozen others if you google something like "collapsing lens on Leica M10" may be of interest.
Edited by Good To Be Retired
vor 47 Minuten schrieb Good To Be Retired:
When the lens is collapsible parts of the lens may extend into the camera and scratch the sensor.
Edited by 01maciel
14 minutes ago, 01maciel said:
When the lens is collapsible parts of the lens may extend into the camera and scratches the sensor.
No sir. Look in the camera and the first thing you see is the shutter. THAT is what would be hit first. Collapse the lens while it’s off the camera and see how far the rear sticks out while collapsed. It doesn’t stick out far enough on the lens to hit anything. It is recommended to mount it while extended so as not to scratch the throat of the camera. Once mounted it won’t reach far enough into the camera to hit anything.
The one I have is a 2.0 Summicron from 1956.
Edited by jdlaing
