Guest Posted October 29, 2020 Share #1 Posted October 29, 2020 Advertisement (gone after registration) As I understand it, the M10 viewfinder magnification is 0.73x, compared to 0.72 for the film bodies. I was expecting it to be essentially the same in use, but actually, far from it - I can see quite a bit more around the (for example) 50mm framelines on my film bodies, compared to my M10-D. I do wear glasses, but that shouldn't make any difference in a like for like comparison of course. Does anybody know why this might be, and/or have noticed the same thing? It really is quite a significant difference, relatively speaking - I can see the 35mm lines quite comfortably with my MP and M-A, but have to move my eye around quite a bit more to see the lines with the M10. Link to post Share on other sites More sharing options...
Advertisement Posted October 29, 2020 Posted October 29, 2020 Hi Guest, Take a look here Viewfinder Question (Compared to MP/M-A). I'm sure you'll find what you were looking for!
jdlaing Posted October 29, 2020 Share #2 Posted October 29, 2020 Are you sure the MP is not a .58 viewfinder? They were available with .58, .72 and .85 viewfinders. Link to post Share on other sites More sharing options...
Guest Posted October 29, 2020 Share #3 Posted October 29, 2020 Yes I'm sure. Link to post Share on other sites More sharing options...
Jeff S Posted October 29, 2020 Share #4 Posted October 29, 2020 What differences in field of view, if any, are there if you press your eye, without glasses, close to each VF? This might better account for differences in VF eye relief (increased with M10 along with increases in magnification and VF diameter) and any issues relating to your frame thickness and flexibility, even though that’s not your normal practice. Jeff Link to post Share on other sites More sharing options...
Guest Posted October 30, 2020 Share #5 Posted October 30, 2020 I can’t tell any difference when I do that really, although that might partly be because I can’t see much without my glasses! I know the M10 is supposed to have “30% better” eye relief than the previous model, which is partly why I’m surprised by the extra visibility in my film Ms. The additional 0.01 in magnification will obviously nullify the improved eye relief a bit, but you wouldn’t think this much! Link to post Share on other sites More sharing options...
mujk Posted November 1, 2020 Share #6 Posted November 1, 2020 I have the same experience, but don't know the exact reason. It might be that the thicker body and practically same magnification combined with "eye relief improvement" doesn't produce the same result when using glasses. Link to post Share on other sites More sharing options...
mujk Posted November 1, 2020 Share #7 Posted November 1, 2020 Advertisement (gone after registration) A correction to my previous post: its actually not the body of an M10 that is thicker than that of a film M, it's the distance from the front of the body to the back of the ocular that is about 1mm longer. Link to post Share on other sites More sharing options...
