Mikep996 Posted October 8, 2020 Share #1 Posted October 8, 2020 Advertisement (gone after registration) Hi all! I'm regular on the M10 forum, having used Leica M cameras for years. I THINK I am interested in purchasing a Q2 but have some questions that I could not locate answers for in either in the forum or in reading the Leica Q2 manual. Both could easily be the result of my failure to find the info as opposed to the info not being there. 1. When in manual focus using the viewfinder, what are you looking at that confirms focus - an M has a rangefinder patch to align. What does the Q2 have? The only reference I found refers to focus peaking (same as the M display). Is that what the Q2 EVF uses as well? 2. When you put the camera in manual focus with the button on the focus ring, will the camera go back into autofocus "automatically" if you turn the focus ring all the way toward the "A" or do you need to press the button again to put it in auto? 3. From reading the instructions, I want to confirm that (like the M) the display can be set so as to be "off" or to only display the last shot for a few seconds, right? Thanks for any info or pointing me to already existing posts re items 1 and 2. Link to post Share on other sites More sharing options...
Advertisement Posted October 8, 2020 Posted October 8, 2020 Hi Mikep996, Take a look here Q2 manual Focusing?. I'm sure you'll find what you were looking for!
Leica28 Posted October 8, 2020 Share #2 Posted October 8, 2020 1. There is a magnified image of the area under focus 2. Yes 3. Yes Link to post Share on other sites More sharing options...
ianforber Posted October 8, 2020 Share #3 Posted October 8, 2020 The magnified area (which you can select to be 3x or 6x) is always a magnification of the central part of the EVF. So if you want to focus on an object off to one side you do exactly as you would with a rangefinder - focus with it in the central part of the EVF and then recompose Link to post Share on other sites More sharing options...
Mikep996 Posted October 8, 2020 Author Share #4 Posted October 8, 2020 In manual is the focusing via a split image (or something similar) or simply "seeing" that it's sharp or blurry? Link to post Share on other sites More sharing options...
Leica Guy Posted October 8, 2020 Share #5 Posted October 8, 2020 3 hours ago, ianforber said: The magnified area (which you can select to be 3x or 6x) is always a magnification of the central part of the EVF. So if you want to focus on an object off to one side you do exactly as you would with a rangefinder - focus with it in the central part of the EVF and then recompose This is incorrect. On the Q2 you can move the focus area with the 4-way controller. Then the camera will magnify that area when the focus ring is moved. It will revert back to unmagnified after approx. 6 secs. You can push the Thumb Wheel Button and the magnified area will remain magnified and not time out for I’d guess 30 secs. This was a change added in a firmware update and is much better than focus and recompose. 5 2 Link to post Share on other sites More sharing options...
Fgama Posted October 8, 2020 Share #6 Posted October 8, 2020 4 hours ago, ianforber said: The magnified area (which you can select to be 3x or 6x) is always a magnification of the central part of the EVF. So if you want to focus on an object off to one side you do exactly as you would with a rangefinder - focus with it in the central part of the EVF and then recompose If you do this at close focusing distance wide open, you risk of getting the wrong focus point. You get perfect focus by moving the focus point using your d-pad. Although I find it difficult to do this when your eye is on the viewfinder. I wish Q2 comes with joystick for this. Link to post Share on other sites More sharing options...
Fgama Posted October 8, 2020 Share #7 Posted October 8, 2020 Advertisement (gone after registration) 3 hours ago, Mikep996 said: In manual is the focusing via a split image (or something similar) or simply "seeing" that it's sharp or blurry? It’s either with focus peaking (you can change the colour) or by magnified image at the focus point (which shows you how sharp/blurry the object is). Personally I prefer to do it without focus peaking nor magnified image as I find them distracting. 1 Link to post Share on other sites More sharing options...
ianforber Posted October 8, 2020 Share #8 Posted October 8, 2020 2 hours ago, Leica Guy said: This is incorrect. On the Q2 you can move the focus area with the 4-way controller. Then the camera will magnify that area when the focus ring is moved. It will revert back to unmagnified after approx. 6 secs. You can push the Thumb Wheel Button and the magnified area will remain magnified and not time out for I’d guess 30 secs. This was a change added in a firmware update and is much better than focus and recompose. Thank you for correcting me - I didn’t know that! 1 Link to post Share on other sites More sharing options...
nico4444 Posted October 10, 2020 Share #9 Posted October 10, 2020 On 10/8/2020 at 7:32 AM, Mikep996 said: Hi all! I'm regular on the M10 forum, having used Leica M cameras for years. I THINK I am interested in purchasing a Q2 but have some questions that I could not locate answers for in either in the forum or in reading the Leica Q2 manual. Both could easily be the result of my failure to find the info as opposed to the info not being there. 1. When in manual focus using the viewfinder, what are you looking at that confirms focus - an M has a rangefinder patch to align. What does the Q2 have? The only reference I found refers to focus peaking (same as the M display). Is that what the Q2 EVF uses as well? 2. When you put the camera in manual focus with the button on the focus ring, will the camera go back into autofocus "automatically" if you turn the focus ring all the way toward the "A" or do you need to press the button again to put it in auto? 3. From reading the instructions, I want to confirm that (like the M) the display can be set so as to be "off" or to only display the last shot for a few seconds, right? Thanks for any info or pointing me to already existing posts re items 1 and 2. Honestly, all of your answers are best found at a dealer shop and by trying for yourself. One does not get the Q(2) to shoot manually most of the time, because it is fundamentally different than shooting with a rangefinder. First of all, the lens is not “manual” per se, because the focus gear and aperture gear are not mechanical, but rather controlled by wire, unlike M lenses, which are completely mechanical. Anyway, I will try to answer your questions as succinctly as possible. 1. Focus peaking is the same as in the M10 with the benefit of being in the EVF, which is not optical, so you get a bright and clear electronic screen as a viewfinder instead of an optical viewfinder. No rangefinder, but focus peaking. 2. On the focus gear, when you turn it to all the way to infinity, you hold a button on the focusing tab and it will latch when you turn the focus gear further beyond towards infinity. You will get a better idea when you try it yourself, but it is pretty simple. 3. Yes, it is customizable, but you might need some help in setting it up correctly and in the way you want it. Finally, I would highly suggest you to go into a dealership and get your answers there, because it is far more practical, given the nature of your questions. Link to post Share on other sites More sharing options...
Mikep996 Posted October 10, 2020 Author Share #10 Posted October 10, 2020 Thanks all, appreciate the replies. I totally agree, Nico, that I should look at one "in person," but it's not convenient at all and I felt like the answers to the questions I had would determine if I wanted to go any further. I don't care for the focus peaking that the M10 uses though, since I almost never use the display for composing, that really doesn't matter. Of course, with the Q2, that IS the focus method (on manual) But I suspect I'd get used to it and it would be perfectly OK. Link to post Share on other sites More sharing options...
nico4444 Posted October 10, 2020 Share #11 Posted October 10, 2020 5 hours ago, Mikep996 said: Thanks all, appreciate the replies. I totally agree, Nico, that I should look at one "in person," but it's not convenient at all and I felt like the answers to the questions I had would determine if I wanted to go any further. I don't care for the focus peaking that the M10 uses though, since I almost never use the display for composing, that really doesn't matter. Of course, with the Q2, that IS the focus method (on manual) But I suspect I'd get used to it and it would be perfectly OK. I will remind you again that the focus gear on the Q2 is not mechanical and in my opinion, manual focus on the Q(2) does not feel as satisfying as a fully mechanical lens. More often than not, I suspect you will find yourself using AF, which is one of the biggest selling points for getting a Q(2). 1 Link to post Share on other sites More sharing options...
jwr50 Posted October 10, 2020 Share #12 Posted October 10, 2020 14 minutes ago, nico4444 said: More often than not, I suspect you will find yourself using AF, which is one of the biggest selling points for getting a Q(2). I agree with this. I've used (and loved) M cameras and lenses for decades, but I recently picked up a Q2 to complement my M10-R. The manual focus on the Q2 is different than manually focusing a rangefinder M camera, but one of the principal benefits of the Q2 is the AF capability. I have found the Q2's AF to be quite good and, frankly, I rarely use manual focus on the Q2. If it's manual focus you want, why not stick with the Leica M? Link to post Share on other sites More sharing options...
pibitller Posted October 10, 2020 Share #13 Posted October 10, 2020 the meter scale is correct in Q2? Working with hyperfocal is better with M lenses, is my conclusion! Link to post Share on other sites More sharing options...
marchyman Posted October 10, 2020 Share #14 Posted October 10, 2020 18 hours ago, nico4444 said: . One does not get the Q(2) to shoot manually most of the time, because it is fundamentally different than shooting with a rangefinder. I shoot my Q using manual focus well over 95% of the time. The difference between using it and my M is zoom/focus peaking on the Q vs the M's rangefinder split image. I do not find that to be fundamentally different. 1 Link to post Share on other sites More sharing options...
nico4444 Posted October 10, 2020 Share #15 Posted October 10, 2020 3 minutes ago, marchyman said: I shoot my Q using manual focus well over 95% of the time. I find that hard to believe, but I guess to each their own. Link to post Share on other sites More sharing options...
snooper Posted October 11, 2020 Share #16 Posted October 11, 2020 11 hours ago, nico4444 said: I find that hard to believe, but I guess to each their own. I use the Q2 full manual (focus, aperture, speed and ISO) almost all of the time. And I really love it. I cant do the same with the SL2, unfortunately, but to me the Q and the M are really close, much more than what I thought initially. Link to post Share on other sites More sharing options...
M11 for me Posted October 11, 2020 Share #17 Posted October 11, 2020 With manual focus I see a big handicap in the fact that the button on top that I have normally set to change the ISO does not work as that any more . . . It just shows the zoomed image even though that same image I can see when turning the focus-wheel. There are a few things that are not well thought through with this camera whereas with my M10 I am 120% happy. 1 Link to post Share on other sites More sharing options...
brickftl Posted October 11, 2020 Share #18 Posted October 11, 2020 23 hours ago, nico4444 said: I will remind you again that the focus gear on the Q2 is not mechanical and in my opinion, manual focus on the Q(2) does not feel as satisfying as a fully mechanical lens. More often than not, I suspect you will find yourself using AF, which is one of the biggest selling points for getting a Q(2). couldn't disagree more 4 Link to post Share on other sites More sharing options...
brickftl Posted October 11, 2020 Share #19 Posted October 11, 2020 On 10/8/2020 at 10:54 AM, Fgama said: It’s either with focus peaking (you can change the colour) or by magnified image at the focus point (which shows you how sharp/blurry the object is). Personally I prefer to do it without focus peaking nor magnified image as I find them distracting. no, it's not "either or". I have magnification PLUS focus peeking, and together they suit my purposes well. 1 Link to post Share on other sites More sharing options...
brickftl Posted October 11, 2020 Share #20 Posted October 11, 2020 others may disagree, but for me using Q2 buttery smooth manual focus wheel together with magnification and peeking is a joy. I only use AF when shooting moving street scenes. For all other shots, stationary and/or standing still portraits I go with manual focus. 4 Link to post Share on other sites More sharing options...
