dadu007 Posted October 1, 2020 Share #1  Posted October 1, 2020 (edited) Advertisement (gone after registration) Hello, so the charts in the links below, and the R-E manual indicate that TTL is possible on R-E with the SCA 351 adapter I am using with the Metz 32 Z2 flash. https://www.bhphotovideo.com/FrameWork/charts/comp_metzflash_leica.html https://www.bhphotovideo.com/FrameWork/charts/comp_metzflash_leica_2.html The flash fires, but before and after firing, the red triangle in the top right of the viewfinder flashes continuously...it's flashing faster than the 2 flashes per second I would expect (probably like 3-4 times a second), no shutter speed is indicated, and then less that the 8 flashes per second after a (supposedly correct) exposure, as one would expect. My hunch is the flash is going off at full power. flash is set to TTL same behavior in either A program focal length setting and iso setting on flash match that of the camera. Battery check is good for R-E and the 32 Z2 flash Anybody have any experience with TTL on the Leica R-E? Thanks! Edited October 1, 2020 by dadu007 Quote Link to post Share on other sites More sharing options...
Advertisement Posted October 1, 2020 Posted October 1, 2020 Hi dadu007, Take a look here Flashing red triangle with R-E and Metz 32 Z2 flash. I'm sure you'll find what you were looking for!
