BFMount Posted August 22, 2020 Share #1 Posted August 22, 2020 Advertisement (gone after registration) Hi I am new to Leica Q. Mounting a used SF24d, the flash works fine in manual mode as expected. I know it does not provide TTL never use it anyway. The problem is exposure preview cycling. Link to video showing the behaviour - https://photos.app.goo.gl/zSdGYgHrTUL69tLE8. Is the flash defective? It works fine. I read the Q's manual and the Flash manual. My thought was a setting somewhere but I cannot find it. A couple ways to 'solve' it: - If I turn off the camera setting exposure preview 'pasm' and change it to 'pas' the problem is solved, but is that the correct answer? - If I change to P, A, S, the problem goes away. Only in Manual do I get the 'warning' / exposure preview cycle. If the flash is mounted, why does the Q still complain and try to tell me I am under exposed? Thank you! Link to post Share on other sites More sharing options...
Advertisement Posted August 22, 2020 Posted August 22, 2020 Hi BFMount, Take a look here Help Please - Leica Q with SF24D Flash mounted - unwanted exposure preview . I'm sure you'll find what you were looking for!
AndrewDD Posted August 26, 2020 Share #2 Posted August 26, 2020 Setting it to PAS is the correct answer. That's how I set my Q2 (and previously Q) when using flash. I had the same problem on a TL2 I briefly owned - it doesn't have the option to switch to PAS. That was the main reason I quickly got rid of it. Link to post Share on other sites More sharing options...
