I just got the S007 and 70mm lens.  I am loving the combo, truly an amazing camera.    I am wanting to get a wide angle lens.   I am usually primarily a 28S Shooter, but mostly because there isn't a 24mm Summicron-M.    I am curious how the 30mm and 35mm S lenses compare?   would mostly do landscape and architecture work with the occasional portrait or astro shot.
I am also curious how prominent the AF motor issue is and should I only get lenses that have had the replacement already done or not?
Thank you
I only have the 35mm, so I cannot compare the two, but I would say that in general with the S system all the lenses are good, and it is more important to get the focal length you need, rather than one being so much better or worse than the others, with the exception of the 30-90 zoom, 120 TS and 100mm Summicron, which are all a bit different from the rest of the line.
Regarding the AF motor, the failure is pretty prominent. Only buy a lens without the AF gear if you are willing to part with the time and money for the replacement. I can't recall the replacement cost, but I believe it might be around 250 euros, not including tax and shipping etc. Your 007 focuses faster than the 006 and S2, so it is more likely to cause problems with the vulnerable lenses.
hey,  Thank you.  I think I will lean toward the 35mm, just because the ones im seeing all have the AF motor replacement, and the 30mm doesn't.
I was debating the 30-90, but prefer primes with the system.
Good to know, the only other lens I have is the 70, which will likely have to get the motor replacement at some point.
I thought about doing that.  however I am leaning heavily toward getting the 35 now, and then down the line the 24 so I will have the 24, 35, 70.   I feel the 35 gives me a more versatile lens for every day
2 minutes ago, ropo54 said:
If you are so inclined for the S 35mm, there's one for sale on Fred Miranda Buy/Sell.
Regards, Rob
FS- Leica S Summarit-S 35mm f-2.5 with Updated AF Motor - FM Forums.webloc 101 B · 1 download
Much appreciated.  I have a lead on a local one that an acquaintance is selling, although I will keep that in mind.  thank you
I had the same question a few years back. Their published MTF is almost identical, as are their size and price. For me the key difference was that the 35 has a bit less distortion, so I went with that one. I remember reading that they were designed at the same time, and have similar optical formulas, so their "look" is very similar.
You can't go wrong with either lens, provided they are in good condition, and you are aware of their AF motor status. You can save quite a bit of money on a lens that hasn't had its motor replaced, but it will cost you time and aggravation down the road (and hopefully less money than you saved up-front). Leica should be able to confirm the warranty and motor status of a potential purchase.
Just for price reference, LSB have a secondhand 35mm in stock.
From me another vote for the 24mm, which I have, together with the 70mm CS and 120mm CS. I completely agree with Stuart's assessment of the lens line, I would love to try out the Summicron myself. If you like the angle of a 28mm in 35 mill terms, if I were you, I would certainly go for the 35mm S first.
In the meantime, don't forget to enjoy your 70mm, it is a great lens, I had it with me as my only lens when I went to Berlin for two weeks and I didn't regret for a moment having only one lens with me, everything just seemed to fit nicely in the normal perspective of the 70mm. The lens is ultra sharp and some say it's not so good for landscape because of field curvature but for every scene with a clear subject matter within 15 meters, wide open - or any other aperture for that matter - the images it produces certainly look very pleasant to my eyes.
35mm is a little smaller and lighter.
Also ask yourself how many lenses do you want to carry? I usually do not like to carry more than 2 for longer time/hikes.
Thats the reason why my 24 and 35 often stay at home and I bring the 30 instead, together with a longer lens like 70 for example.
For my taste 35 is better for people in environment and street, and 30 better for ladndscape and architecture.
Thank you all for the wonderful responses.   It was very good to read and very informative.
  I ended up going with a 35mm from a local photographer/acquaintance.  he was selling it, and has had the motor replacement.
 I am very excited to have a 35/70 pairing.
Understand completely about the size and weight.   I would likely hike with the S and one lens, and my M10R and another lens, so I would likely choose complimenting focal lengths for that.
4 minutes ago, John McMaster said:
I will be curious to see how long you carry both cameras, the M(240) is my most recent M but it cannot compare to the results I get from my S(007)....
john
+1. Despite sharing the same sensor, as is the case for M10-R and S3. Interesting, albeit not fully surprising - the end result (=raw file) depends on all factors involved; sensor + sensor size + in-body processing + lenses, etc.
7 hours ago, helged said:
... the end result (=raw file) depends on all factors involved; sensor + sensor size + in-body processing + lenses, etc.
Indeed, including what’s bonded to the sensor... cover glass(es), etc.  The same sensor architecture (cut from the same wafer) can end up with Bayer array, or none (Monochrom), or even Fuji X-Trans, as Sony has shown with multi-company sales partnerships.
Jeff
vor 22 Stunden schrieb neekon:
70 and 35 were my first two lenses when the S2 appeared and I think it is a very good combo.
