LUF Admin Posted July 16, 2020 Share #1 Posted July 16, 2020 Advertisement (gone after registration) More: Leica M10-R | Video Interview | Jono Slack Review Leica M10-R: Technical Data Camera type Leica M10-R, compact digital view and range finder system camera Lens attachment Leica M bayonet with additional sensor for 6-bit coding Lens system Leica M lenses, Leica R lenses can be used with an adapter (available as an accessory) Shot format/picture sensor CMOS chip, active surface approx. 24 x 36mm Resolution DNG™ 7864 x 5200 pixels (40,89MP), JPEG: 7840 x 5184 Pixel (40,64MP), 5472 x 3648 Pixel (20 MP), 2976 x 1984 Pixel (6MP) Data formats DNG™ (raw data, 14 bit, compressed loss-free), JPEG (8 bit) File size DNG™ 40-60 MB, JPEG: Depending on resolution and picture content Buffer memory 2GB / 10 pictures in series White balance Automatic, manual, 8 presets, color temperature input Storage medium SD cards up to 2GB/SDHC cards up to 32GB/SDXC cards up to 2TB Menu languages German, English, French, Spanish, Italian, Portuguese, Japanese, Traditional Chinese, Simplified Chinese, Russian, Korean Exposure metering Exposure metering through the lens (TTL), with working aperture; Metering principle/method For metering the light reflected by light blades of the 1st shutter curtain onto a measuring cell: Strong center-weighted; for metering on the sensor: Spot, center-weighted, multi-field metering Metering range At room temperature and normal humidity for ISO 100, at aperture 1.0 EV-1 to EV20 at aperture 32. Flashing of the left triangular LED in the viewfinder indicates values below the metering range Sensitivity range ISO 100 to ISO 50000, adjustable in 1/3 ISO increments, choice of automatic control or manual setting Exposure modes Choice of automatic shutter speed control with manual aperture preselection - aperture priority A, or manual shutter speed and aperture setting Flash exposure control Flash unit attachment Via accessory shoe with central and control contacts Synchronization Optionally triggered at the 1st or 2nd Shutter curtain Flash sync time = 1/180s; slower shutter speeds can be used, if working below sync speed: Automatic changeover to TTL linear flash mode with HSS-compatible Leica system flash units Flash exposure metering Using center-weighted TTL pre-flash metering with Leica flash units (SF40, SF64, SF26), or flash units compatible with the system with SCA3502 M5 adapter Flash measurement cell 2 silicon photo diodes with collection lens on the camera base Flash exposure compensation ±3EV in1⁄3EV increments Displays in flash mode (in viewfinder only) Using flash symbol LED Viewfinder Construction principle Large, bright line frame viewfinder with automatic parallax compensation Eyepiece Calibrated to -0.5 dpt.; corrective lenses from -3 to +3 diopter available Image field limiter By activating two bright lines each: For 35 and 135mm, or for 28 and 90mm, or for 50 and 75mm; automatic switching when lens is attached. Parallax compensation The horizontal and vertical difference between the viewfinder and the lens is automatically compensated according to the relevant distance setting, i.e. the viewfinder bright-line automatically aligns with the subject detail recorded by the lens. Matching viewfinder and actual image At a range setting of 2m, the bright-line frame size corresponds exactly to the sensor size of approx. 23.9 x 35.8mm; at infinity setting, depending on the focal length, approx. 7.3% (28mm) to 18% (135mm) more is recorded by the sensor than indicated by the corresponding bright line frame and slightly less for shorter distance settings than 2m Magnification (For all lenses) 0.73 x Large-base range finder Split or superimposed image range finder shown as a bright field in the center of the viewfinder image Effective metering basis 50.6mm (mechanical measurement basis 69.31mm x viewfinder magnification 0.73x) Displays In the viewfinder Four-digit digital display with dots above and below On back 3” color -TFT LCD monitor with 16 million colors and 1,036,800 pixesn, approx. 100% image field, glass cover of extremely hard, scratch-resistant Gorilla® glass, color space: sRGB, for Live-View and review mode, displays Shutter and shutter release Shutter Metal blade focal plane shutter with vertical movement Shutter speeds For aperture priority: (A) continuous from 125s to 1⁄4000s., for manual adjustment 8s to 1⁄4000s in half steps, from 8s to 125s in whole steps, B: For long exposures up to maximum 125s (in conjunction with self-timer T function, i.e. 1st release = shutter opens, 2nd release = shutter closes), (1⁄180s): Fastest shutter speed for flash synchronization, HSS linear flash mode possible with all shutter speeds faster than 1⁄180s (with HSS-compatible Leica system flash units) Picture series approx. 5 pictures/s, 30-40 pictures in series Shutter release button Two-stage, 1st step: Activation of the camera electronics including exposure metering and exposure lock (in aperture priority mode), 2nd step: Shutter release; standard thread for cable release integrated. Self-Timer Delay optionally 2s (aperture priority and manual exposure setting) or 12s, set in menu, indicated by flashing LED on front of camera and corresponding display in monitor. Turning the camera on/off Using main switch on top of camera; optional automatic shutdown of camera electronics after approx. 2/5/10 minutes; reactivated by tapping the shutter release Power supply 1 lithium ion rechargeable battery, nominal voltage 7.4V, capacity 1300mAh.; maximum charging current/voltage: DC 1000mA, 7.4V; Model No.: BP-SCL5; Manufacturer: PT. VARTA Microbattery, Made in Indonesia, Operating conditions (in camera): 0°C - + 40°C Charger Inputs 100-240V AC, 50/60Hz, 300mA, automatic switching, or 12V DC, 1.3A; Output: DC 7.4V, 1000mA/max. 8.25V, 1100mA; Model No.: BC-SCL5; Manufacturer: Guangdong PISEN Electronics Co., Ltd., Made in China, Operating conditions: 0°C - + 35°C GPS (only with Leica Visoflex viewfinder attached, available as an accessory) Optional (not available everywhere due to country-specific legislation, i.e. enforced automatic shutdown in those countries), data are written to EXIF header in picture files. Wifi Complies with IEEE 802.11b/g/n standard (standard Wifi protocol), channel 1-11, encryption method: Wifi-compatible WPA™/WPA2™ encryption, access method: Infrastructure mode Camera body Material All-metal die cast magnesium body, synthetic leather covering. Brass top panel and base, black or silver chrome plated finish Image field selector Allows the bright-line pairs to be manually activated at any time (e.g. to compare detail) Tripod thread A ¼ (¼“) DIN stainless steel in bottom Operating conditions 0-40°C Interfaces ISO accessory shoe with additional contacts for Leica Visoflex viewfinder (available as an accessory) Dimensions (width x depth x height) approx. 139 x 38.5 x 80mm Weight approx. 660g (with battery) Scope of Delivery Charger 100-240V with 2 mains cables (Euro, USA, varies in some export markets) and 1 car charging cable, lithium ion battery, carrying strap, body bayonet cover, cover for accessory shoe 1 Link to post Share on other sites More sharing options...
Advertisement Posted July 16, 2020 Posted July 16, 2020 Hi LUF Admin, Take a look here Leica M10-R: Technical Data . I'm sure you'll find what you were looking for!
