Hello,
I bought a used M240 and when looking through the test shots I noticed a white pixel appearing in the same place in every image. I then took a complete black picture (ISO 200) and then found 6 of such 1x1 pixels spread all over the sensor. 2 of these are grey.
Now my question is if this is a common thing with this camera or not? Is it something most people just don't notice? The seller didn't mention them but I also didn't think of asking because I never noticed anything like that on any other camera before.
Is it true that Leica can map these out? If so how much will that cost approximately?
Do faults like these exist in the sensor from the start, do they happen with age or are they an indicator of certain misuse?
I know I can easily edit them out in Capture One but I feel sad since I paid a price expecting the camera to be pristine technically. I didn't plan on selling it anytime soon but I wonder if this will make the resell value drop by a lot.
Edited by jowatt
Hot pixels are not normal, as the sensor is mapped at production, but may appear over time. The sensor can be mapped out by Leica, but only if the number of mapped pixels stays within the tolerance span. Otherwise you are looking at an (expensive) sensor replacement.  Personally I would return the camera.
vor 26 Minuten schrieb jaapv:
Over how long and how many do usually appear? After all the M240 is quite old now.
Is the tolerance span something Leica can determine from the test image or do I need to send in the camera?
I sadly don't think I am able to return it since I bought it from a private seller.
You bought a used camera. Nothing wrong with that. If you wanted pristine you should have bought brand new.
If you bought a pristine camera you still don’t know what is underneath.
Am 13.7.2020 um 01:58 schrieb jdlaing:
I am just wondering if this is something to be expected as the camera is quite old now or if it's a fault. If you take a black frame with your camera do you see any pixels? Or do most people not pay attention to details like that?
Coincidentally I noticed a couple of stuck pixels on my 240.
I went through some photos to see if they’d always been there, and long story short, there’s been some pixels that have stuck and unstuck over the months I've had the camera.
From what I understand adobe maps them out upon import (and stuck pixels I can find in C1 aren’t there in the same image in LR) but in C1 you’ll need the single pixel sider on the noise reduction tool. A value of 1 usually does the job
If you send an image to Leica showing the pixels they will advise you. All digital cameras get dead pixels.
Am 19.7.2020 um 01:24 schrieb Adam Bonn:
Since they appear at ISO 200 I guess they are stuck pixels?
Am 21.7.2020 um 02:30 schrieb jaapv:
There are stories of people fixing pixels by keeping the camera in the freezer overnight. It may well be a myth - at your own risk.
That sounds crazy.
Also I just noticed that there are 2 times as many and some of them are in color.
Could any other M240/262 owners take a black frame (lens cap on, ISO 200, f/16, 1/4000) and tell me if they see any pixels at all at 100%+ magnification? It's quick and easy to do and it would help me a lot! I still don't understand if this is something that can happen or if it's a rare issue and a potential sign of a sensor going broken a la M9 corrosion.
Edited by jowatt
It may well be crazy - that is the Internet for you. ;)
Hot/stuck pixels are something that can/will happen and has no relation to a sensor dying and certainly nothing at all with corrosion, as corrosion is not a sensor defect. The f stop is irrelevant as well. Just send the DNG to Leica for evaluation, they can tell you exactly what to do. Asking on a forum will not lead to any meaningful conclusion.
Normally Leica will map them out, should the number exceed the tolerance, they will replace the sensor.
vor 11 Minuten schrieb jaapv:
I did. They told me that they haven't seen anything like this which is worrying. My dilemma is that in this current state I can deal with it but my big fear is that it might get much worse.
It would just be nice to have an idea of how common that is. Do others have no stuck pixels, a few, or also a lot like me? I meant like corrosion as in getting worse. I worry that it will go from just a few pixels to the sensor being covered in them.
I noticed a stuck pixel on my 240
So I had a look for more and found 2
I swapped to c1 from lr recently and it turns out that Adobe maps then out automatically
In c1 try a value of 1 to 5 on the single pixel slider in the noise reduction tool
I decided to check all my photos since I got the camera secondhand as I wondered if they had always been there
No
I also found a stuck pixel that has since unstuck
So maybe yours will go away
Did leica advise to send the camera in?
Don't try the freezer thing... If you do take the sensor out of the camera first!
