Boojay Posted June 25, 2020 Share #21  Posted June 25, 2020 Advertisement (gone after registration) The above has me worried.  Just checked my version 2 pre Asph 35 Lux, Canada, have no idea if it has ever been modified but the black shroud is there, used on M240 and M10, again now on M240 and have never noticed any issue with infinity, focus ring is smooth throughout the entire range, do not see any marks inside the body.    Link to post Share on other sites More sharing options...
Advertisement Posted June 25, 2020 Posted June 25, 2020 Hi Boojay, Take a look here 2nd hand Summilux-M 35mm F/1.4 (1980) vert stiff focus lever. I'm sure you'll find what you were looking for!
darylgo Posted June 25, 2020 Share #22  Posted June 25, 2020 1 minute ago, Boojay said: The above has me worried.  Just checked my version 2 pre Asph 35 Lux, Canada, have no idea if it has ever been modified but the black shroud is there, used on M240 and M10, again now on M240 and have never noticed any issue with infinity, focus ring is smooth throughout the entire range, do not see any marks inside the body.    I checked two copies of the ver 2 on an M240 variant and an M10-P, no issues with the shroud. I do not know if it was modified by the previous owner(s).  Link to post Share on other sites More sharing options...
jdlaing Posted June 25, 2020 Share #23  Posted June 25, 2020 (edited) 5 minutes ago, Boojay said: The above has me worried.  Just checked my version 2 pre Asph 35 Lux, Canada, have no idea if it has ever been modified but the black shroud is there, used on M240 and M10, again now on M240 and have never noticed any issue with infinity, focus ring is smooth throughout the entire range, do not see any marks inside the body.    Same here. While I had it it worked fine. Edited June 25, 2020 by jdlaing 1 Link to post Share on other sites More sharing options...
jdlaing Posted June 25, 2020 Share #24  Posted June 25, 2020 2 minutes ago, darylgo said: I checked two copies of the ver 2 on an M240 variant and an M10-P, no issues with the shroud. I do not know if it was modified by the previous owner(s).  Count the rings. Link to post Share on other sites More sharing options...
Boojay Posted June 25, 2020 Share #25 Â Posted June 25, 2020 24 minutes ago, jdlaing said: Count the rings. Haha - I've been trying to do that... I think mine has seven rings... but how many should it have? Â Â Â Link to post Share on other sites More sharing options...
jdlaing Posted June 26, 2020 Share #26 Â Posted June 26, 2020 1 hour ago, Boojay said: Haha - I've been trying to do that... I think mine has seven rings... but how many should it have? Â Â Â Looks like the one in post #15 has eight. 1 Link to post Share on other sites More sharing options...
Guest JMF Posted June 26, 2020 Share #27  Posted June 26, 2020 Advertisement (gone after registration) 2 hours ago, darylgo said: I checked two copies of the ver 2 on an M240 variant and an M10-P, no issues with the shroud. I do not know if it was modified by the previous owner(s).  Usually this shroud issue happens on the M8 and M9 bodies. Their inner cage is too narrow. Mount the lens focussed at a near distance only , do not mount the lens set at infinity or you might force and foul the lens' calibration. Been there, done it ...! Then if you feel any resistance, don't try focussing any further and have the shroud removed or trimmed. Link to post Share on other sites More sharing options...
darylgo Posted June 26, 2020 Share #28  Posted June 26, 2020 Images of two lenses show eight rings, they don't appear to be modified. One copy has wear on the points where the shroud ends.  The warning continues to be present, P 32 of the M10-P manual: INCOMPATIBLE LENSES – Hologon 15 f/8 – Summicron 50 f/2 with close-up – Elmar 90 f/4 with retractable tube (manufactured 1954- 1968) – Some examples of the Summilux-M 35 f/1.4 (non-aspherical, manufactured 1961-1995, Made in Canada) cannot be attached to the camera or cannot focus to infinity. Leica Customer Care can modify these lenses so that they can be used with the camera.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/310852-2nd-hand-summilux-m-35mm-f14-1980-vert-stiff-focus-lever/?do=findComment&comment=3999354'>More sharing options...
AndreasG Posted June 26, 2020 Share #29  Posted June 26, 2020 (edited) I got a Summilux 35, serial No. 343 30xx, Made in Germany, around 1990, for me, it looks like the lenses shown above, same shroud obviously. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! To avoid any trouble with my M10-D - there is the same warning in the manual as with the M10-P, I simply contacted Leica Customer Service and asked about the compatibility of the lens. Their reply same day was positive, the lens can be used with the M10-D. Seems, depending on origin, Canada/Germany and manufacturing batch No. there are slight dimensional differences of the shroud, therefore, best is to contact customer service to avoid any mechanical damage of lens and/or camera.  See their reply - sorry, in German, below. (Dear Mr. xxxx, thank you for the inquiry, you can use the mentioned Summilux without any trouble with your M10-D. Basically, almost all M lenses can be used with digital M cameras. Limitations you find on page 27 of the manual.) Edited June 26, 2020 by AndreasG Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! To avoid any trouble with my M10-D - there is the same warning in the manual as with the M10-P, I simply contacted Leica Customer Service and asked about the compatibility of the lens. Their reply same day was positive, the lens can be used with the M10-D. Seems, depending on origin, Canada/Germany and manufacturing batch No. there are slight dimensional differences of the shroud, therefore, best is to contact customer service to avoid any mechanical damage of lens and/or camera.  See their reply - sorry, in German, below. (Dear Mr. xxxx, thank you for the inquiry, you can use the mentioned Summilux without any trouble with your M10-D. Basically, almost all M lenses can be used with digital M cameras. Limitations you find on page 27 of the manual.) ' data-webShareUrl='https://www.l-camera-forum.com/topic/310852-2nd-hand-summilux-m-35mm-f14-1980-vert-stiff-focus-lever/?do=findComment&comment=3999388'>More sharing options...
TangoCharlie27 Posted June 26, 2020 Author Share #30  Posted June 26, 2020 (edited) What is the best email to contact Leica regarding this? I am still waiting for a reply regarding the M10-D and manual lens selection (there is no option in the app to select a lens!).  Edited June 26, 2020 by TangoCharlie27 Link to post Share on other sites More sharing options...
AndreasG Posted June 26, 2020 Share #31  Posted June 26, 2020 Why don't you contact the above mentioned Peter Brieger? 1 Link to post Share on other sites More sharing options...
