Wide angle lens?
sm23221
Why buy a wide angle lens when you can very easily stitch together 2 50mm photos?
In concept with a landscape, that would work. Rangefinders are made for wide angles, and if I had to have just one lens to shoot my M8 with, it would be a wide angle (21mm or 24mm). You may not be able to take two overlapped pictures in quick succession with a locked exposure; there may be no substitute for a wide angle. Stitched phots at best look stitched.
IF you've got the time and a static enough subject then obviously you can stitch together many images taken even at longer focal lengths to produce the equivalent of a wide angle view but with enormous resolution. There's nothing new about this.
However, for the other 99.999% of wide angle shots you might prefer a WA lens :D
I think that for landscapes stitching may even be preferred. Normal lenses have less distortion than wide angles, and the increase in resolution means larger prints are possible.
The question is what to stitch with. The only program I have had consistently good results with, often with almost no effort, is Autopano Pro.
Carsten, FYI, the pano stitching feature in CS3 has been a revelation...
John - If you check out the excellent '36 shot panorama' thread Carsten began I think you'll find he is well aware of CS3 improvements, and in terms of the question posed by the original poster to this thread is full of very useful information. With regard to that question, I currently am only shooting landscapes with my M8, have one lens [24], and I'm putting panorama files aside for later stitching [thanks to Carsten's posts, I may well get Autopano Pro for the stitching].
...................Chris
I use Autopano Pro with excellent results. I find it is much better to use a longer (50mm) lenses for landscape panoramics rather than wide angle lenses; it virtually eliminates wide angle distortion and lines end up very straight.
