_sparkie_ Posted June 1, 2020 Share #1 Posted June 1, 2020 Advertisement (gone after registration) Hey Everyone, I have been lurking here for a long time but I finally have a question that you may be able to help me with. Over the last few weeks a small problem has developed with the two red dots in the centre rewind mechanism on my MP. They have come loose, it's like the rewind knob is somehow also turning the red dots when I am winding up a roll. The red dots fell off recently, luckily I was at my desk and didn't loose the piece but I need to find a way to screw it back down and secure it. Has anyone else ever had this problem and is there a way I can solve it myself without having to send it away for repair? Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted June 1, 2020 Posted June 1, 2020 Hi _sparkie_, Take a look here MP rewind problem, any advice?. I'm sure you'll find what you were looking for!
250swb Posted June 2, 2020 Share #2 Posted June 2, 2020 (edited) There is a tool with two pegs that fits into the depressions filled with red paint, it is in effect a kind of screwdriver. Place the part back in position with the tool in place and with an ordinary broad bladed screwdriver turn the shaft from the inside of the camera using the notch that engages the fill spool. If you hold the peg tool securely in a fixed position as you tighten from the inside it should stop you scratching the exterior paint. The necessary tool can be bought from eBay. You might want to put a tiny dab of thread lock onto the threads before you tighten. Edited June 2, 2020 by 250swb 1 Link to post Share on other sites More sharing options...
Mute-on Posted June 2, 2020 Share #3 Posted June 2, 2020 (edited) It is also possible to make the two peg tool by either: 1. Sacrificing a flat screwdriver of the required width by grinding away the centre to create two “horns” 2. Clamping two metal skewers in a pair of locking pliers at the correct distance apart, after first grinding or sanding down the tips to a blunt profile In any case, wrap all metal parts of your tool in masking or other tape to protect against damage, but use soft electrical tape over the tips to avoid scratching the red paint. Also wrap the flat bladed screwdriver that you use to lock the rewind fork in place with tape to avoid damage to the fork and film chamber. Good luck! Edited June 2, 2020 by Mute-on Link to post Share on other sites More sharing options...
_sparkie_ Posted June 2, 2020 Author Share #4 Posted June 2, 2020 Thanks lads, a friend of mine who is an industrial designer with a workshop has said he will do it with the correct tools. 1 Link to post Share on other sites More sharing options...
Mute-on Posted June 3, 2020 Share #5 Posted June 3, 2020 Brilliant Sparkie. Love my MP Link to post Share on other sites More sharing options...
_sparkie_ Posted June 3, 2020 Author Share #6 Posted June 3, 2020 54 minutes ago, Mute-on said: Brilliant Sparkie. Love my MP Yeah, I love mine too, so much that I'm on the hunt for another one at the moment. Hopefully I can get this sorted today and back to work. Link to post Share on other sites More sharing options...
_sparkie_ Posted June 9, 2020 Author Share #7 Posted June 9, 2020 (edited) Advertisement (gone after registration) Ok, I think I got it fixed but I have one more question. I put something in the forks to hold them in place and got a tool to tighten down the red dots. Can someone else with a MP check something for me, if you put your finger on the turning forks, is there about a 1/4 turn latency between the rewind knob and the forks turning? Is that normal or ar they ment to be directly equal? Edited June 9, 2020 by _sparkie_ Link to post Share on other sites More sharing options...
TomB_tx Posted June 9, 2020 Share #8 Posted June 9, 2020 There is some backlash or free play between the knob and fork by design. I don’t have an MP, but on my M2&3 models it’s about 10 degrees. 1 Link to post Share on other sites More sharing options...
Yaakov Posted June 10, 2020 Share #9 Posted June 10, 2020 16 hours ago, _sparkie_ said: Ok, I think I got it fixed but I have one more question. I put something in the forks to hold them in place and got a tool to tighten down the red dots. Can someone else with a MP check something for me, if you put your finger on the turning forks, is there about a 1/4 turn latency between the rewind knob and the forks turning? Is that normal or ar they ment to be directly equal? I do feel a little latency, I can't really measure it but it feels more at the beginning of the movement then kind of catches up, at least that is how I feel it. 1 Link to post Share on other sites More sharing options...
_sparkie_ Posted June 10, 2020 Author Share #10 Posted June 10, 2020 Yeah, cool, it seems normal. I think it's finally sorted. Link to post Share on other sites More sharing options...
_sparkie_ Posted July 13, 2020 Author Share #11 Posted July 13, 2020 Famous last words. I appears that after another month of use, the two red dots are loose again. I feel like the pull-up rewind knob is not straight anymore and that rewinding it is rubbing off the red dots, and loosening them. Does anyone know where I can buy a replacement rewind knob? Link to post Share on other sites More sharing options...
250swb Posted July 13, 2020 Share #12 Posted July 13, 2020 And did you use some thread lock? Link to post Share on other sites More sharing options...
_sparkie_ Posted July 13, 2020 Author Share #13 Posted July 13, 2020 12 minutes ago, 250swb said: And did you use some thread lock? I didn't. My main reason being that if the parts are rubbing off each other because the rewind shaft is not straight, I didn't want to cause more mechanical damage by forcing them to crash together. If there is an easy way to source a rewind knob, I think that will do it. Have you used threadlock before to solve this exact problem? Link to post Share on other sites More sharing options...
dkmoore Posted July 13, 2020 Share #14 Posted July 13, 2020 35 minutes ago, _sparkie_ said: I didn't. My main reason being that if the parts are rubbing off each other because the rewind shaft is not straight, I didn't want to cause more mechanical damage by forcing them to crash together. If there is an easy way to source a rewind knob, I think that will do it. Have you used threadlock before to solve this exact problem? DAG or Leica NJ if you are in the USA. Link to post Share on other sites More sharing options...
250swb Posted July 13, 2020 Share #15 Posted July 13, 2020 8 hours ago, _sparkie_ said: I didn't. My main reason being that if the parts are rubbing off each other because the rewind shaft is not straight, I didn't want to cause more mechanical damage by forcing them to crash together. If there is an easy way to source a rewind knob, I think that will do it. Have you used threadlock before to solve this exact problem? The cap with the two red dots on it is just that, a screw cap. It doesn't affect the rewind shaft or how much parts rub off against each other. A thread lock compound is just to secure it into it's thread, it doesn't force anything to do anything, only the operator can do that. Nothing is going to 'crash together' unless you aren't telling us the whole truth and that the shaft itself is bent. But given your lack of mechanical aptitude in understanding this and using words like 'rubbing' and 'crash' I think you aren't up to a simple job and you should absolutely definitely send it back to Leica. Link to post Share on other sites More sharing options...
_sparkie_ Posted July 14, 2020 Author Share #16 Posted July 14, 2020 14 hours ago, 250swb said: The cap with the two red dots on it is just that, a screw cap. It doesn't affect the rewind shaft or how much parts rub off against each other. A thread lock compound is just to secure it into it's thread, it doesn't force anything to do anything, only the operator can do that. Nothing is going to 'crash together' unless you aren't telling us the whole truth and that the shaft itself is bent. But given your lack of mechanical aptitude in understanding this and using words like 'rubbing' and 'crash' I think you aren't up to a simple job and you should absolutely definitely send it back to Leica. You seem upset. Have a cup of tea, go outside, perhaps take a few deep breaths. Link to post Share on other sites More sharing options...
250swb Posted July 14, 2020 Share #17 Posted July 14, 2020 A simple idea that works was presented to you, take it or leave it. Link to post Share on other sites More sharing options...
