pewimap Posted May 6, 2020 Share #1 Posted May 6, 2020 Advertisement (gone after registration) I have a silver M10p, but it had a problem. I open Leica Fotos to turn on Wifi, but it keep rotating and stop at this screen for hours, and it cannot starting any WLAN. The firmware is latest. And this is the first time I use this function when I bought it. And it did not work. Hope you can help Thanks Link to post Share on other sites More sharing options...
Advertisement Posted May 6, 2020 Posted May 6, 2020 Hi pewimap, Take a look here Leica M10P serious wifi issue. I'm sure you'll find what you were looking for!
scott kirkpatrick Posted May 6, 2020 Share #2 Posted May 6, 2020 I use Fotos with my M10-D, which is very similar to the M10-P but needs Fotos to set some of its parameters. It works fine. Have you done the following: Turn camera ON Menu > third or fourth menu page and Fotos . turn it ON (I moved this to the favorites page, which comes up first Now when the WiFi startsd you will have a square code showing on the LCD Start Fotos., go to add new camera, select M10-P capture the bar code with the phone's camera If it doesn't connect on the first try, try again. pressing the shutter button on the camera to wake it up may help. I sometimes takes more than one try. Link to post Share on other sites More sharing options...
pewimap Posted May 7, 2020 Author Share #3 Posted May 7, 2020 Hi Scott, Seems the camera could not start the wifi, so my phone can not find the wifi to connect. really sad about this Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 7, 2020 Share #4 Posted May 7, 2020 No square code, does a square code show up on the LCD but no wifi signal? You can check for the signal being present by using your phone. Go to Systems/WiFi, and click on the current WiFi connection to see a list of others that are available. Remember that it takes 1-2 minutes for the Leica wifi chip to warm up and present a signal. Link to post Share on other sites More sharing options...
pewimap Posted May 7, 2020 Author Share #5 Posted May 7, 2020 No square code, no wifi signal appears on my phone... really upset with this Leica Link to post Share on other sites More sharing options...
scott kirkpatrick Posted May 8, 2020 Share #6 Posted May 8, 2020 Don't be upset. Visit a store or call Leica if no store is near. As long as you are navigating the menus properly your camera has a problem and there are warranties for this. Link to post Share on other sites More sharing options...
AndreasG Posted May 8, 2020 Share #7 Posted May 8, 2020 Advertisement (gone after registration) Did you follow the instruction on p101 of the manual (direct connection) to set up the WLAN? Link to post Share on other sites More sharing options...
