Hi everyone I just got a red Elmar but the filter I got is thicker than the actual lens ahah could anyone recommend me better / thinner 19mm filter options for this lens? Thank you!
The early small screw in filters are not that common. The usual ones to use are the clamp-on type in A36 size, but they are bigger overall.
From your picture it looks like the lens has not been extended, if it is a 50mm lens? Or is it a 35mm Elmar?
Thank you, it’s the 50mm. The problem with those filters is that we can’t change the aperture that’s why I was looking for 19mm that screw into the lens.
vor 2 Stunden schrieb shirubadanieru:
Hi everyone I just got a red Elmar but the filter I got is thicker than the actual lens ahah could anyone recommend me better / thinner 19mm filter options for this lens? Thank you! ...
I got two 19mm filters made by Kenko, but they are also thicker than slim original Leitz 19mm filters.
Every 19mm filter makes it somewhat more difficult to adjust the aperture of the Elmar - but without a protecting filter, fingerprints easily get onto the front lens.
•  Leica M 8.2  •  'cron 50 coll.  •  SOMKY  •  Graph. Conv.  •  Stuttgart  •  July 2013.  •
I also use the heliopan 19mm filter on an Elmar (3,5cm but same filter diameter).
The thickness could be considered as a bonus. Wiithout the hood, (I don't have one yet)
the rim protects (just a little…) more from stray light than a slim filter would.
