jaapv Posted August 17, 2007 Share #101 Posted August 17, 2007 Advertisement (gone after registration) So folks a good lesson today , is if you run into this just back off the focusing very slightly, images will still be plenty sharp but you can avoid this. Kinda puts the backfocus threads into perspective doesn't it? It's an asset! Link to post Share on other sites More sharing options...
Advertisement Posted August 17, 2007 Posted August 17, 2007 Hi jaapv, Take a look here Best M8 DNG converter?. I'm sure you'll find what you were looking for!
hankg Posted August 17, 2007 Share #102 Posted August 17, 2007 You can fix it manually in post (providing there is no detail in the moire). Mask out the offending section and copy and paste it to another layer. The green channel has the least moire in this case so I used channel mixer to make all 3 channels duplicates of the green so less blur is needed. Blur the image until the moire is gone. Use the mask to KO the bleed at the edges. Color balance to match the original. It doesn't take long for something like this but I wouldn't want to be fixing a whole catalog of images. I did a partial section indicated by the red lines so you could compare. Second one has a slight amount of grain added for texture. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/30919-best-m8-dng-converter/?do=findComment&comment=331798'>More sharing options...
hankg Posted August 17, 2007 Share #103 Posted August 17, 2007 You could also composite in focus and slightly out of focus shots if you are photographing static objects from a tripod. But that won't be the case for event photographers or the odd bit of moire that unexpectedly pops up. Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted August 17, 2007 Share #104 Posted August 17, 2007 Thanks Hank I will try that today Link to post Share on other sites More sharing options...
jlm Posted August 17, 2007 Share #105 Posted August 17, 2007 re the M8 and tethered: any hints about Capture 1, 4 still due out in 2007? Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted August 17, 2007 Share #106 Posted August 17, 2007 John if you want to shoot tetehered with C1 you still have to use the digital capture software , than with C1 like LR you have to point to the same folder for it to work. So both software packages are open and working. i think that is the work around for C1 , in LR you auto import from that same folder. I usually make a folder on the desktop and use that Version 4 is overdue from there promised dates Link to post Share on other sites More sharing options...
ericperlberg Posted August 17, 2007 Share #107 Posted August 17, 2007 Advertisement (gone after registration) ... Version 4 is overdue from there promised dates I was under the impression that 4.0 lite was due out in early summer (hence overdue) but that heavy(?) was due at the end of 07. Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted August 17, 2007 Share #108 Posted August 17, 2007 I heard May for LE and July for Pro. Link to post Share on other sites More sharing options...
teehas53 Posted August 17, 2007 Share #109 Posted August 17, 2007 ... it can happen and you don't know until post time. When working in a controlled environment (like Guy's studio shot,) if you notice the moire at the time of capture, often rotating the camera a few degrees will eliminate or greatly reduce it. Also, moving slightly closer or farther away from the subject can have a similar effect. Making the pattern of the weave a different size or orientation is the key. Then you simply straighten the shot with a re-crop in post. Doesn't always work completely, but it does almost always HELP, and reduces post-process fiddling (and time!) T Link to post Share on other sites More sharing options...
ericperlberg Posted August 17, 2007 Share #110 Posted August 17, 2007 I heard May for LE and July for Pro. That was in the original photokina 06 press release wasn't it? Here's a thread with posts from Keith Carpentar at Phase One Support comments on releases. A summary might be: Posted on June 14 2007 "Full Support with Free UpDate 3.7.8 due at end of this month / early July 4.0 LE version UpGrade will arrive first followed by the PRO and DB versions. All versions are expected later this year ~ 2007~ when they are ready for Final Release." Posted on June 26 2007 "Currently, there is only an LE Alpha version, and No Beta Version of 4.0 is available. " With LE in Alpha in late June one can only guess the rest. Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted August 17, 2007 Share #111 Posted August 17, 2007 Thanks Eric for finding that Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted August 17, 2007 Share #112 Posted August 17, 2007 Well I did it and it took some work but i did a lot of lasso and feather and used surface blur which wiped it out completely but than i had to be careful with lines and such . But than added grain and brought it back . It looks pretty good now. Whew that was a little work Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/30919-best-m8-dng-converter/?do=findComment&comment=332006'>More sharing options...
Guest guy_mancuso Posted August 17, 2007 Share #113 Posted August 17, 2007 heres the orginal again Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/30919-best-m8-dng-converter/?do=findComment&comment=332007'>More sharing options...
