Jeff Wagner Posted March 21, 2020 Share #1 Posted March 21, 2020 Advertisement (gone after registration) I’ve tried shooting panoramic images with the CL and rarely do they turn out well. Looking at the image in LR it is all chopped up vertically. What am I doing wrong? Link to post Share on other sites More sharing options...
Advertisement Posted March 21, 2020 Posted March 21, 2020 Hi Jeff Wagner, Take a look here Panoramics. I'm sure you'll find what you were looking for!
jaapv Posted March 21, 2020 Share #2 Posted March 21, 2020 Switch on the artificial horizon and turn in a straight line. Set the exposure to manual. Link to post Share on other sites More sharing options...
david strachan Posted March 21, 2020 Share #3 Posted March 21, 2020 (edited) Or use a tripod for best panoramas. They do take some planning of the sequence. Don't choose a too-wide angle lens as the edge distortions won't blend. Lots of overlap between frames. Manual exposure is definitely required. ... Edited March 21, 2020 by david strachan Link to post Share on other sites More sharing options...
jaapv Posted March 22, 2020 Share #4 Posted March 22, 2020 Actually, in-camera panorama modes do quite well hand-held. On a tripod it is not that easy to swivel at the rate that the camera requires. Link to post Share on other sites More sharing options...
FrozenInTime Posted March 23, 2020 Share #5 Posted March 23, 2020 (edited) Try not to tilt the camera up and include about a third of a frame overlap, and the CL works well even with 180 horizontal degree views. If you need a large vertical coverage, overlap frames even more and also include a untilled level sweep in the set. CL with 18-56 handheld.( click on image for 4k view ) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited March 23, 2020 by FrozenInTime 7 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/307678-panoramics/?do=findComment&comment=3937636'>More sharing options...
caigy Posted March 23, 2020 Share #6 Posted March 23, 2020 The panorama function on the CL does work, but I invariably find that the quality is not as good as simply taking a series of 3-5 overlapping photos as you manually pan the camera across the scene. This can be done with the camera horizontal or vertical, and I've posted examples of both. I find it best to overlap 1/3 of the previous image on each of the next frames, and then I merge them in Photoshop. Unless you are using very slow shutter speeds, a tripod isn't necessary. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 7 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/307678-panoramics/?do=findComment&comment=3937651'>More sharing options...
geoffreyg Posted March 26, 2020 Share #7 Posted March 26, 2020 Advertisement (gone after registration) all pretty impressive. Link to post Share on other sites More sharing options...
Mr.Prime Posted March 26, 2020 Share #8 Posted March 26, 2020 On 3/23/2020 at 4:55 PM, FrozenInTime said: Try not to tilt the camera up and include about a third of a frame overlap, and the CL works well even with 180 horizontal degree views. If you need a large vertical coverage, overlap frames even more and also include a untilled level sweep in the set. CL with 18-56 handheld.( click on image for 4k view ) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! this is superb! Link to post Share on other sites More sharing options...
jaapv Posted March 28, 2020 Share #9 Posted March 28, 2020 This is a handheld in-camera one from the CL. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 7 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/307678-panoramics/?do=findComment&comment=3941429'>More sharing options...
WeiterWinkel Posted March 29, 2020 Share #10 Posted March 29, 2020 Am 23.3.2020 um 21:55 schrieb FrozenInTime: Try not to tilt the camera up and include about a third of a frame overlap, and the CL works well even with 180 horizontal degree views. If you need a large vertical coverage, overlap frames even more and also include a untilled level sweep in the set. CL with 18-56 handheld.( click on image for 4k view ) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Skyfall? 😉 2 Link to post Share on other sites More sharing options...
