SocialKonstruct Posted March 15, 2020 Share #1 Posted March 15, 2020 Advertisement (gone after registration) Curious if there any 35mm lens adapters for the S mount around? Link to post Share on other sites More sharing options...
Advertisement Posted March 15, 2020 Posted March 15, 2020 Hi SocialKonstruct, Take a look here 35mm lens adapters for S mount?. I'm sure you'll find what you were looking for!
John McMaster Posted March 15, 2020 Share #2 Posted March 15, 2020 Only the Leica one for the SL john Link to post Share on other sites More sharing options...
Joakim Posted March 15, 2020 Share #3 Posted March 15, 2020 19 minutes ago, John McMaster said: Only the Leica one for the SL john It’s for the L mount to be more precise but maybe it will not have all of the functionality on other L cameras? Link to post Share on other sites More sharing options...
frame-it Posted March 15, 2020 Share #4 Posted March 15, 2020 8 hours ago, SocialKonstruct said: Curious if there any 35mm lens adapters for the S mount around? https://fotodioxpro.com/collections/lens-mount-adapters/products/l39-viso-ls-pro Link to post Share on other sites More sharing options...
Sarnian Posted March 15, 2020 Share #5 Posted March 15, 2020 I use an adapted lens - the Samyang 24mm T/S (no longer T/S after the adaption): https://www.dropbox.com/s/m1xri32njl14ipw/Samyang 24mm non-TS Nikon version.tif?dl=0 Link to post Share on other sites More sharing options...
Sarnian Posted March 15, 2020 Share #6 Posted March 15, 2020 1 hour ago, frame-it said: https://fotodioxpro.com/collections/lens-mount-adapters/products/l39-viso-ls-pro I've got one of these but I can't figure out what to do with it! 😵 Link to post Share on other sites More sharing options...
frame-it Posted March 15, 2020 Share #7 Posted March 15, 2020 Advertisement (gone after registration) 19 minutes ago, Sarnian said: I've got one of these but I can't figure out what to do with it! 😵 easy..slap on a vintage summitar or summar or industar, crop the final output and see how that lovely sensor captures from those gorgeous lenses. i don't have that adapter but i do have the M > G adapter for fuji...example 50mm summilux M ASPH on GFX50R Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/307449-35mm-lens-adapters-for-s-mount/?do=findComment&comment=3931817'>More sharing options...
davidmknoble Posted March 15, 2020 Share #8 Posted March 15, 2020 15 hours ago, SocialKonstruct said: Curious if there any 35mm lens adapters for the S mount around? I don't believe it will use the full frame, but a cropped section? Link to post Share on other sites More sharing options...
frame-it Posted March 15, 2020 Share #9 Posted March 15, 2020 6 hours ago, davidmknoble said: I don't believe it will use the full frame, but a cropped section? here is a full image without cropping Link to post Share on other sites More sharing options...
frame-it Posted March 15, 2020 Share #10 Posted March 15, 2020 one more Link to post Share on other sites More sharing options...
davidmknoble Posted March 16, 2020 Share #11 Posted March 16, 2020 3 hours ago, frame-it said: here is a full image without cropping I see, on the Fuji, which is mirrorless. Understood. But the S3 because it is a DSLR has a longer focusing distance which is the problem..Thanks for the clarification. Link to post Share on other sites More sharing options...
frame-it Posted March 16, 2020 Share #12 Posted March 16, 2020 2 hours ago, davidmknoble said: I see, on the Fuji, which is mirrorless. Understood. But the S3 because it is a DSLR has a longer focusing distance which is the problem..Thanks for the clarification. which is one of the reasons "some" people want a mirrorless S, but others want the OVF 1 Link to post Share on other sites More sharing options...
davidmknoble Posted March 16, 2020 Share #13 Posted March 16, 2020 8 hours ago, frame-it said: which is one of the reasons "some" people want a mirrorless S, but others want the OVF You are correct. I think that is why Leica has the SL and SL2, which take M, L, and S lenses, and left the S as the OVF with lenses integrated to the body allowing other medium format lenses to be used. Then everyone has a choice and with the new sensors the choice provides larger files. Link to post Share on other sites More sharing options...
frame-it Posted March 16, 2020 Share #14 Posted March 16, 2020 7 hours ago, davidmknoble said: You are correct. I think that is why Leica has the SL and SL2, which take M, L, and S lenses, and left the S as the OVF with lenses integrated to the body allowing other medium format lenses to be used. Then everyone has a choice and with the new sensors the choice provides larger files. yes...except i realized last year that once the camera reaches 50MP, at least for me, its better to move to a larger format, so i sold my 51MP 5DSR and moved to the GFX 1 Link to post Share on other sites More sharing options...
frame-it Posted March 17, 2020 Share #15 Posted March 17, 2020 and 1 Link to post Share on other sites More sharing options...
davidmknoble Posted March 17, 2020 Share #16 Posted March 17, 2020 4 hours ago, frame-it said: and I knew there is an S-R adapter that works well with the APO R 280 f/2.8 (and I actually have a great copy that lens with the case). That particular lens, on the S is essentially full frame. I am waiting for a new batch to be made from someone I am ordering... I use that lens on the SL now along with the 1.4x APO adapter... This was taken with the SL, not the S, but at f/2.8 with the 1.4x extender. It shows that there would be a good use on the S series ... Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/307449-35mm-lens-adapters-for-s-mount/?do=findComment&comment=3933251'>More sharing options...
SocialKonstruct Posted March 21, 2020 Author Share #17 Posted March 21, 2020 With 35mm lens on a medium format body, there can be some vignetting possible. I gather that some lenses have such solid resolving power beyond that of the 35mm format which is pretty awesome... Due to the COVID-19 situation, I have reassessed any huge purchases lately and honestly I feel that a Leica Q2 is pretty ideal for most shooting atm... but going to wait and see. Link to post Share on other sites More sharing options...
John McMaster Posted March 21, 2020 Share #18 Posted March 21, 2020 You meant a 35mm format lens on the S? There are almost no lenses with a larger register than the S (~47mm) as well as issues with mirror clearance. I tried my R 80/1.4 on my S a few years ago, fine for portraits but would not focus much beyond that.... john Link to post Share on other sites More sharing options...
Sarnian Posted March 21, 2020 Share #19 Posted March 21, 2020 The converted 24mm Samyang T/S that I use covers the entire S frame due to it having a large image circle so that it could accommodate the shift movements that it was intended for. So, Tilt/Shift lenses are probably your best starting point. http:// https://www.dropbox.com/s/m1xri32njl14ipw/Samyang 24mm non-TS Nikon version.tif?dl=0 Link to post Share on other sites More sharing options...
