Taken with M10-P and 24mm Elmar.
Canary Wharf from Blackwall Basin by biotecbob, on Flickr
Nice. this one could use a bit more contrast and lifted midtones for me, plus sharpening for screen, but that is personal taste. If you like I could post my version.
Thanks, yes I would be interested in seeing your version. I think I could do with getting a better understanding of post processing.
What I did:  I adjusted exposure and blackpoint (there was some clipping in the blacks) in ACR, then I pulled up the midtones in curves and applied linear contrast, then I made a layer, hit "sharpen" and pulled the opacity down to 30%. Flattened, converted to RGB (some browsers may struggle with grayscale)
Most of this can be done in LR as well; it took more time to write down than to do.
Edit: I cheated too ;) I removed the thingie on the upper left hand side and gave the lettering on the buildings a swipe with the sharpening brush @ 10%.
