Alf62 Posted March 6, 2020 Share #1  Posted March 6, 2020 Advertisement (gone after registration) Dear fellow Leica Forum members, After a number of years being able to resist buying a Noctilux 0.95,  I actually bought one today đ I just feel I am ready after having gained enough experience with an M and SL cameras to tam it ... My copy does rotate a bit beyond the 0.95 fixing point of which I have read in different forums that this is not necessarily an issue ... However, my copy has play in the aperture ring; or it wobbles a bit (if this is the right expression). May I kindly ask you if those with an 0.95 have experience this as well? Do I need to send it back? Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted March 6, 2020 Posted March 6, 2020 Hi Alf62, Take a look here Noctilux 0.95 aperture ring wobbles. Question. I'm sure you'll find what you were looking for!
Gelatino Posted March 6, 2020 Share #2  Posted March 6, 2020 On my copy of Noctilux 0,95 no play/wobble on the aperture ring at all. It goes 1 or 2 mm beyond the 0,95 click,  but that won't let me think I own a 0,80 lens though. Link to post Share on other sites More sharing options...
Alf62 Posted March 7, 2020 Author Share #3  Posted March 7, 2020 Thanks. Appreciate your feedback. I was expected the 1 to 2mm beyond the 0.95 click might not be an issue but am afraid that play/wobble in the ring is. I think I am going to return it for repair/replacement. Thanks! 1 Link to post Share on other sites More sharing options...
Gelatino Posted March 7, 2020 Share #4  Posted March 7, 2020 Thinking of some thing to check that may cause your problem. Look at the little screw under the shade. On my summilux50 which has the same type of shade, the screw was gone so the front ring could move and the aperture ring too.If the screw is only loose just need to tighten it (more surely glue it with very little nail varnish), if gone get it replaced. Link to post Share on other sites More sharing options...
Alf62 Posted March 7, 2020 Author Share #5  Posted March 7, 2020 2 hours ago, Gelatino said: Thinking of some thing to check that may cause your problem. Look at the little screw under the shade. On my summilux50 which has the same type of shade, the screw was gone so the front ring could move and the aperture ring too.If the screw is only loose just need to tighten it (more surely glue it with very little nail varnish), if gone get it replaced. Thank you Gelatino! I have checked the two little screws under the shade. One seems to be more turned in than the other. I donât dare to âtry this at homeâ and will ask the Leica shop to have a look. If this is the issue, I will let you know but may thanks for this hint! Cheers. 1 Link to post Share on other sites More sharing options...
