Did you try to press the center button (23)?
Thanks for your response.I did press the center button. And I went through the drill of removing / reinserting the battery. The gridline is the only "Capture Assistant" that works.
(I also note, in passing, that after the firmware update, the focus point ("+") has acquired a life of its own, jumping between shots to wherever it wishes. Not a life-changing problem, of course, but it does require hunting it down before the next shot.)
Did you set all the capture assistants to "On"? If so you may wish to save a profile with those settings.
